Author Topic: glove box handle  (Read 3804 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: glove box handle
« Reply #15 on: 01 July 2014, 20:43:38 »
does the end panel just pull off.
Magwheels
    • 2.2 dti Elite saloon
« Reply #16 on: 01 July 2014, 22:31:23 »
Yep, end panel just pulls off from the vent end. Needs wiggling about to get out past the door seal once the front is loose but as long as you don't just yank it off you should be fine.
Then one screw at bottom and one at top for air vent. Pull air vent forward and out minding the lighting wire and bulb at the back. Two further screws behind air vent to remove. Rest as per previous comments.
« Last Edit: 01 July 2014, 22:34:14 by Magwheels »
