Author Topic: Spanner light on but driveable.  (Read 3869 times)
Re: Spanner light on but driveable.
« Reply #15 on: 02 July 2014, 19:40:55 »
Yes I have every intention of replacing the cam sensor, the query is regarding reading number 2 code PO700 re transmission control module, sorry if I appear "thick" .
Cam sensor (P0340 in engine ECU) often causes engine ECU to give invalid data to TCM (which will be a P1700 in the TCM), which causes TCM to tell engine ECU to use reduced power (P0700 in engine ECU)
2boxerdogs
« Reply #16 on: 04 July 2014, 20:04:41 »
New sensor just fitted , codes cleared & spanner light out !! Just hope that is the end of that problem..
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #17 on: 04 July 2014, 20:12:10 »
Are they still around the £80 mark
2boxerdogs
« Reply #18 on: 04 July 2014, 20:14:28 »
Yep, £72.00 plus VAT = £86.40 .
Steve B
  • Leicestershire
« Reply #19 on: 04 July 2014, 20:17:18 »
Its a lot of money for such a small bit of platic  ;D ;D ;D ;D
Is it 40 000 we should get out of them :-\
2boxerdogs
« Reply #20 on: 04 July 2014, 20:58:37 »
Don't know how long they last ,the 2.2 is an 03 plate has done almost 96,000 miles , I have every bill  for it from day 1 and as far as  I can tell it has never had  replacement before.
« Reply #21 on: 04 July 2014, 22:41:29 »
Should last 100k, mine failed at around 105k I think. New GM one went on then, still good at 174k.
Steve B
  • Leicestershire
« Reply #22 on: 04 July 2014, 22:44:57 »
Mine went at 50K
« Reply #23 on: 04 July 2014, 22:46:54 »
Generally they last over 100k, if geniune at least, FatherT's 2.2 never had a cam sensor changed ever and it went 130k  :y
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
« Reply #24 on: 05 July 2014, 07:25:35 »
hi. i had the exact same thing with mine not long back , had new cam senser now it runs like a dream, good luck. :y
« Reply #25 on: 05 July 2014, 09:43:40 »
Luck of the draw how long they last. I suspect age is as big a factor as mileage TBH.
2boxerdogs
« Reply #26 on: 05 July 2014, 21:04:58 »
Well the car has had a real good blast today, performed perfectly so fingers crossed all is now well...
Page created in 0.043 seconds with 20 queries.
