Author Topic: Oil filter housing  (Read 3706 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Oil filter housing
« on: 05 July 2014, 20:21:03 »
How do you remove a housing from a 2.6 face lift when the whole body turn, I know others have had this in the past? This 2.6 I got hold off must have been service by a right d#%k last time! why do it up so tight. :o
Re: Oil filter housing
« Reply #1 on: 05 July 2014, 21:15:33 »
Can you rotate the body a complete turn? There's supposed to be a lug on the back of it to stop it moving more than a couple of mm :-\
If you can indeed turn it 360°, then try putting pressure between the housing and the block as you turn it... this might unscrew the retaining bolt :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #2 on: 05 July 2014, 21:51:37 »
Just to clarify, are you trying to undo the end cap but the body is turning, or do you want to remove the body.
If it's the end cap, you could use a strap wrench on the body to stop it turning and a socket on the end cap.
If it's the body, are you trying to undo the hollow bolt?  :-\
Sorry if I've got the wrong end of the stick.  :)
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #3 on: 05 July 2014, 22:15:08 »
OK, so the body is turning 360deg and I have had a go with a strap wrench, still turns the whole thing. I have taken one of them off before ( the whole thing which is why I have a spare). It's not unscrewing just going round and round. There is not enough room to get a Stilson on it to hold it, and the strap wrench (chain type) will not hold it, it dug in and put a mark on the outside of the body but still the whole thing turns :-\
Thing is I don't know the service history of this car, did they do it up so tight it snapped the lug off? I just don't know. I may have to destroy it to get it off, but I think I will confirm the location of the spare first ;)
Makes me wonder when the filter was last changed :-\
chrisgixer
« Reply #4 on: 05 July 2014, 23:40:16 »
I think the issue is the length of time between oil changes. Oil gets in the threads and effectively glues that cap on with heat. I know I do mine up to barely tight, but if I leave the oil change too long, it takes proportionately more effort to undo the longer its left undisturbed ime.
Not something us oofers will encounter normally, once it's undone of course.
As said though, needs a way to hold the body still while undoing the cap. Strap wrench etc.
First time I did my first 3.2, nearly pulled the car off the stands it was that tight/glued on. :(
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #5 on: 05 July 2014, 23:49:28 »
Took mine off an replaced with the correct type of filter the spin on type.  :y :y
chrisgixer
« Reply #6 on: 05 July 2014, 23:52:47 »
Makes no odds once its loose though. Still got to get the damn thing off.
YZ250
« Reply #7 on: 06 July 2014, 00:18:46 »
As the seal is an O Ring and the problem is caused by gunked/fried oil, I wonder if you could get a bit of localised heat to the end of it without damaging anything else, or would it fry it on more?  :-\
Pretty close to crank sensor but are there any other cables nearby.  :-\
Strap wrench on, socket at the ready, blow lamp on and being very careful it might just work. A second pair of hands would help, so that it doesn't cool down too much. Put a solder mat over the top to protect other bits.
I don't mean fry it, just warm it up a bit. New filter comes with a new O Ring anyway.  :y
Obviously common sense comes in to it where flammable liquids are concerned.
Does that sound a bit dangerous.  ::) ;D
Next post will be:
Well you see, I was using this blow lamp on my petrol engine when .......... ;D ;D
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #8 on: 06 July 2014, 08:34:18 »
I did think about a blow lamp but very quickly put it out of my mind. :y will report later with any update.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 06 July 2014, 09:21:12 »
Find your spare and break it off, :y
« Reply #10 on: 06 July 2014, 10:31:47 »
Once you have done it, you need to remove the whole thing and refit properly.
As dr.gixer says, I suspect its either last done by a monkey, or it hasn't been done for a while.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #11 on: 06 July 2014, 10:57:16 »
As the lug must have come off  :o :o I am going to break up the body below the cap then remove the whole thing as I have found my spare ::) ::) but the cap on that is not 100% but the one on the car is. More to follow
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #12 on: 06 July 2014, 12:48:14 »
Spare housing now on the car with a nice new filter to boot. :y had to slowly smash the old housing under the cap depth, so as not to damage it ( will remove that at a later date, old housing did not have a lug ever, the spare has but they have different markings on the inside
Old has 1/1
Spare has 1/3 with a 3/4 round lug so body can only turn about 10 deg each way :y
« Reply #13 on: 06 July 2014, 13:38:09 »
Obviously a development at some point, probably as a result of warranty claims for seized caps...
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #14 on: 06 July 2014, 14:08:52 »
Think you could be right :y how many have the dealers had to take off like this
