Pages: 1 [2] 3  All   Go Down
Author Topic: Caravan ?  (Read 9806 times)
Re: Caravan ?
« Reply #15 on: 10 July 2014, 18:44:08 »
I used to sell static caravans and was always getting into trouble with my manager for bringing in damp tourers in part ex!!  ;D
Deals a deal i thought!  :y
Re: Caravan ?
« Reply #16 on: 10 July 2014, 22:50:13 »
Static, my kind of caravan................. ;) ;) :y
Matchless
  • Nottingham
    • A white van
Re: Caravan ?
« Reply #17 on: 11 July 2014, 13:17:27 »
Been looking around for caravans .. thoughts on this one anyone and what to look out for ?
Lunar clubman
We had a 4-berth version of that model for many years, luxurious for the time,fully insulated double glazed and winterised, sprung interior upholstery, real oak for the cupboard frames and doors etc.
It would be about the last year to have an aluminium chassis which is great for keeping the weight down but have a good look around the tow hitch and axle attachments for signs of corrosion where steel meets aluminium. They had rubber or plastic material to keep the two metals apart so you shouldnt see any significant corrosion.
The roof is a one-piece fibreglass moulding which was unusual for the time, result is very unlikely to have leaked from above. Any leaks and rot would be below windows.
The rear push/pull/curse_swimbo handles are missing, this would suggest some dampness and rot behind the rear panel, quite common in a 'van of this age but easy to fix with basic woodworking skills and modern polyurathane glues.
The floors on these were some of the very first laminated ply/polyurethane foam/fibre board construction and early ones suffered from delamination just inside the doorway and by the sink. Can be fixed by drilling holes and injecting resin but best avoided.
Axles were by Knott but usually had Alko hubs and brakes so spares readily available.
Budget for new (reinforced) tyres.
Re: Caravan ?
« Reply #18 on: 11 July 2014, 13:26:45 »
12V electrics is actually quite easy / cheap to mend .. unless master control panels fail ...
HTH  :)
And even then, you open up the 'master control panels' and find nothing more then 20 quids worth of bits in the form of a few relays and a switch mode supply with charging capability.....so they are not hard to DIY repair  :y
Re: Caravan ?
« Reply #19 on: 11 July 2014, 13:34:06 »
This is my kind of caravan:
..............ahh, perhaps not, maybe this really is my ideal caravan:
 ;D ;D ;D ;D ;D ;)
Re: Caravan ?
« Reply #20 on: 11 July 2014, 13:44:36 »
Lunar clubman
Extensive information there M'less  :y Im guessing that with age the older caravans will suffer from the panels becoming brittle  :-\ As you say any wood rot can be cut out and re done .. if it had carpet i would rip that out for starters then re furb the interior doors/floors ect ....  :y
Are you still limited to a certain speed for towing a caravan  :-\
bored bigyin54
  • south wales
    • black beast
Re: Caravan ?
« Reply #21 on: 11 July 2014, 13:50:56 »
60 mate ;D ;D
bored bigyin54
  • south wales
    • black beast
Re: Caravan ?
« Reply #22 on: 11 July 2014, 13:51:53 »
 ;D ;D ;D ;D ;D ;)
need a truck to tow that ;D ;D
Re: Caravan ?
« Reply #23 on: 11 July 2014, 13:55:39 »
60 mate ;D ;D
Plenty fast enough for me  :) Think the most ill be doing is 30 mph till i get use to towing  ;D
Re: Caravan ?
« Reply #24 on: 11 July 2014, 14:06:46 »
It's amazing the difference you can make to an old Van with a dehumidifier, a tube of silicone and a pot of emulsion!!  :y
Not that I'd advocate such bodging and would advise a full and comprehensive restoration!  :)
Re: Caravan ?
« Reply #25 on: 11 July 2014, 14:12:52 »
60 mate ;D ;D
not quite true .... :(
60 mph on a dual carriageway when a higher or the national speed limit applies,
50 mph on a single carriageway when a higher or the national speed limit, applies,
at all other times the speed limit as posted.
HTH and sorry for being pedantic ...  but I'd hate to see someone "done" for lack of information :)
« Last Edit: 11 July 2014, 14:14:47 by Entwood »
Re: Caravan ?
« Reply #26 on: 11 July 2014, 14:13:48 »
Do caravans need gas and electric safe certificates  :-\
Re: Caravan ?
« Reply #27 on: 11 July 2014, 14:14:50 »
Dunno, but don't forget it will need a full geometric setup at WIM!  :y
Re: Caravan ?
« Reply #28 on: 11 July 2014, 14:16:10 »
Nope, no legislation to enforce that, BUT for safety sake they are a good idea, and theoretically a commercial site could refuse you if they asked for the certificate and you don't have one.
Re: Caravan ?
« Reply #29 on: 11 July 2014, 14:17:14 »
 ;D
Maybe a tyre thread for caravans next  :-X
 :y ;)
Pages: 1 [2] 3  All   Go Up
