Author Topic: Inconsistently stalling  (Read 6637 times)
Omega VT3000
  • Essex
« on: 15 July 2014, 13:23:41 »
Hi all,
I wonder if any of you fine Omega wizards can assist with a quirky issue with my Omega please?
The car has been off the road for the thick end of 2 years. I have replaced the plugs and coil pack as it previosuly had a misfire across the whole rev range. Having changed the ignition components, the car runs sweet as a nut and flew through an MoT with no issues including good emissions.
Coming home on a long journey at the weekend, the car started to experience an intermittent issue. When you depress the clutch, the revs fall off and the car stalls whilst on the move. That in itself isn't so much of an issue when you are in straight line but coming up to a roundabout it becomes a little dangerous given the PAS assistance disappears. When it is playing up, it can also miss under load. The issue can also disappear quite quickly and the car behaves perfectly.
There is no indication that the problem is occuring until the first stall happens, basically, the revs fall to the idle level (circa 500 rpm) but when it it's playing up, it simply keeps dropping to nothing unless you can get to the throttle to increase the revs. There are no warning lights displayed on the dash and no limp mode indications.
In the two years it was off the road, it was stored in a dry garage with under 1/4 of a tank of fuel. It has since had a fuel tank for fresh fuel mixed in with the two year old stuff.
Any ideas as I am about to take the car off the road again as it is dangerous to drive when the issue arises?
Thanks all.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Inconsistently stalling
« Reply #1 on: 15 July 2014, 13:37:29 »
What Engine?
Omega VT3000
  • Essex
« Reply #2 on: 15 July 2014, 13:38:17 »
Sorry, 3.0 V6 in a 2000 V facelift.
« Reply #3 on: 15 July 2014, 13:41:36 »
ICV or crank sensor are the favourites.
given the occasional miss I would be erring towards the crank sensor
zirk
  • Epping Forest
« Reply #4 on: 15 July 2014, 13:42:25 »
Sounds like a failing Crank Sensor, but no harm in cleaning the ICV first.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #5 on: 15 July 2014, 15:42:57 »
As above, does sound like a failing crank sensor. Same symptoms as my dads when he owned one. It never failed to start but occasionally stalled coming up to a junction and had a very occasional miss-fire. Went fine in between but obviously would have given up in the end.
Is this the police one James?  Don't suppose you still have either of your other omega's to poach one from to confirm it do you, assuming the part number matches?  :-\
Regards
Alan
« Last Edit: 15 July 2014, 15:58:22 by YZ250 »
« Reply #6 on: 15 July 2014, 18:47:31 »
If revs are preventing it, I reckon I might be trying to clean the ICV first.
Try a code reader, or paperclip test (see Guides section) and post up any codes. Ignore any 31s stored, as this could take you down a false line of enquiry.
YZ250
« Reply #7 on: 15 July 2014, 20:30:47 »
No harm in cleaning the ICV first but the miss under load coincides with the stalling, which in our case was the crank sensor.  :-\
Agreed that you shouldn't chuck money at it without confirming though.  :y
« Reply #8 on: 15 July 2014, 22:21:33 »
Being a 3.0l, if no codes are present in the ECU, worth checking over the HT side (visually). DIS, leads and plugs (and plugwells!)
Omega VT3000
  • Essex
« Reply #9 on: 17 July 2014, 21:34:21 »
Cheers all. It has a new DIS and plugs but not leads. I have access to an end of life R-reg so may borrow the ICV and crank sensor off that to see if that helps. I am also wondering if the crank sensor got as wet as the DIS when I was driving it a couple of years ago when the original misfire started and that has knackered it.
« Reply #10 on: 17 July 2014, 22:33:46 »
Crank sensor is sealed, cannot get wet. Not all crank sensors same either. Also adding unknown parts.
Have you read the codes?
Omega VT3000
  • Essex
« Reply #11 on: 17 July 2014, 22:56:09 »
I don't have access to a Tech 2 but the advice came from a Vauxhall tech. His thoughts are to do with wart getting drawn into the wiring causing corrosion as opposed to getting in to the sensor itself.
« Reply #12 on: 18 July 2014, 09:39:57 »
All you need is a paper clip  ;)
http://www.omegaowners.com/forum/index.php?topic=90581.0
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #13 on: 18 July 2014, 10:03:43 »
I would replace the ICV meself first not the crank sensor as the car would be hard to restart if it was that....
ICV is common to drop off revs when coming to idle from a journey, better to replace rather than clean as cleaning tends to make them worse Iv found from experience :)
D.I.L.L.I.G.A.F...
« Reply #14 on: 18 July 2014, 12:00:03 »
Ha ha ha, lol, pmsl......sorry, cant stop laughing.
Looking very much forward to his explanation as to the physics of that.
But yes, beware as there are a couple of crank sensor types and they have slightly different length pickups.
