Omega 2.6 MV6 auto performance.
Started by Field Marshal Dr. Opti, 19 July 2014, 15:08:05
Centre consol, pop it in D then left to change down and right to change up, but nothing fancier than that and certainly not the all singing, all dancing 7G Tronic, flappy paddle gubbins in the new ones :y
Taxi_Driver
Quote from: Taxi Al on 25 July 2014, 22:05:52
Thats still what they call tiptronic  :y
Exactly as on my CLS500. A novelty for about 5 minutes and then never used again. The changes were about as quick as an Omega auto using manual hold. :-\
Quote from: Doctor Opti on 26 July 2014, 10:30:48
Fair dos :y I figured it was just an electrical version of moving the lever through the gears as per an older auto ::)
Taxi_Driver
Quote from: Taxi Al on 26 July 2014, 13:10:50
But you havent answered my orig question......is it faster to change if you whack the gear stick, than using kickdown. I tended to use the tiptronic to make my merc change down......coz it would only kickdown if you pressed the pedal all the way to the floor....ie using loads of fuel....when a 1/2 way on the throttle and use the tiptronic had the same effect, but use less fuel  :-\
Possibly marginally when in E, but no noticeable difference when in S, as near as I can tell :-\
Taxi_Driver
Quote from: Taxi Al on 26 July 2014, 23:12:06
It should be, but dont know why it isnt in S....
As far as i understand it .... If you use kickdown to change gear the ECU has to work out which is the lowest gear it can change to with out over revving....if you are in 5th for example.....hit the tiptronic asking it for 4th, it only has to check 4th wont over rev it....then change....so one less step the ECU has to work out .....just a quick tap on the gearshift is needed....otherwise you'll be finding your asking it to change to 1st  ;D
The time taken for the ECU to work out what gear to change into is insignificant. It really just depends what type of gearbox it's controlling. If it's controlling a slushbox, it'll change gear like a slushbox. If it's a dual clutch box like a DSG it'll be swifter. If it's a "proper" sequential gearbox that can do clutchless shifts it'll be instant.
The mechanism by which it gets told which gear to change into makes no odds. If it's a slushbox, might as well save yourself the hassle and frustration and let the ECU decide, IMHO. ;) On such gearboxes, tiptronic is a marketing fad designed to immitate what you get in a Ferrari whilst giving you gearchanges that take about 3 weeks longer, IMHO. ;)
Quote from: Kevin Wood on 28 July 2014, 23:00:15
3 weeks :o :o......mine was nothing like as quick as that, Kevin. :)
Think eons. ;)
Standard 5 speed slush box :y
Which roughly translates to less shit to go wrong ;D
