Pages: 1 [2] 3  All   Go Down
Author Topic: Relay ?  (Read 5717 times)
Re: Relay ?
« Reply #15 on: 20 July 2014, 22:52:10 »
Wire up towbar electrics direct to loom at rear,
Change 3pin flasher to a 4 pin
Then other relay fits under glove box
Insert bulb for trailer light,
Is that correct as to how ive read everything
yes  :y  :y
* depends on age of car. I forget which way round, but it can live above the driver's feet too  ;)
Splendid , its all making sense now  ;D Vauxhall part mite be cheaper , ill ring them and see .. you never know  :y
« Last Edit: 20 July 2014, 22:58:51 by Emd »
4x4
Re: Relay ?
« Reply #16 on: 20 July 2014, 22:53:25 »
Ok,emd il pop round after work 1 evening and wire it up for you
Re: Relay ?
« Reply #17 on: 20 July 2014, 22:56:18 »
Excellent  :y Hopefully no swarm of attacking wasps this time   :o
Bring soldering iron/solder if you have still got it mate  :y
« Last Edit: 20 July 2014, 22:59:09 by Emd »
Re: Relay ?
« Reply #18 on: 21 July 2014, 14:25:35 »
Well hope i got the right Relay   ::) There was 4 different types with 4 pins but if its wrong i can take it back to Alfods , nice blonde woman didnt have much idea which one i should take either  :-* ;D
Oh it was £6 .
Re: Relay ?
« Reply #19 on: 21 July 2014, 14:34:39 »
Oh it was £6 .
Flasher relay ........  ::) price wise I think you've just got a standard relay ie a switch  ;)
  • Auckland
    • Mazda MPV
Re: Relay ?
« Reply #20 on: 21 July 2014, 14:36:29 »
The Omega has front and rear indicators (each 21 Watts) a side repeater (10 Watts? or maybe also 21 Watts :-\) and an indicator in the dash (1.2 Watts? or 4 Watts?)
Your relay may say something like '21W+21W+10W+1.2W' in which case it should just work.
The first one I tried was too sensitive & saw the side repeater as a trailer. They found me another which was less sensitive and that behaves as it should.
Re: Relay ?
« Reply #21 on: 21 July 2014, 14:39:30 »
All it says is 12v 30 amp  :(
Theres a diagram on the relay looks like this ...
     86              87
      __              o
     |__| _ _ _ _ .\_
       |                  o
      85                 o
                          30
12V                   30A
« Last Edit: 21 July 2014, 14:57:38 by Emd »
Re: Relay ?
« Reply #22 on: 21 July 2014, 14:41:23 »
You've bought a relay  ;) not a flasher 'relay'
Re: Relay ?
« Reply #23 on: 21 July 2014, 14:42:23 »
Do you have somewhere local to you that fits towbars etc? They'll know what you need.  :y
Re: Relay ?
« Reply #24 on: 21 July 2014, 15:05:14 »
Ill have a look ..
What about this  :-\
relay
Re: Relay ?
« Reply #25 on: 21 July 2014, 15:31:02 »
Ill have a look ..
What about this  :-\
relay
Ot looks like it might be ok, I couldn't be certain though
Re: Relay ?
« Reply #26 on: 21 July 2014, 18:17:48 »
Arrrrrgh !!!
Re: Relay ?
« Reply #27 on: 22 July 2014, 15:49:37 »
Still no joy on this relay  >:(
Will this do the job ?
Bypass Relay
Help !!!  :(
Re: Relay ?
« Reply #28 on: 22 July 2014, 17:28:34 »
Bypass Relay
Help !!!  :(
This is the genuine article
Pages: 1 [2] 3  All   Go Up
