Author Topic: Swap from old mid to newer type?  (Read 3381 times)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« on: 21 July 2014, 23:13:21 »
I have a 95 omega with the old type mid. The kind with one black and one yellow connector on the back. The display has the typical missing pixels and its only four years old. Really dont want to pay Opel insane amount of money for a new display which will probably only last a couple of years. Is it possible to fit a newer type mid with just the one grey connector just by modifying the connectors or will there be compability/programming issues? Radio is pioneer afternarket with a display adaptor. Is the newer type mid less prone to pixel failure? All info welcome:)
Re: Swap from old mid to newer type?
« Reply #1 on: 22 July 2014, 05:58:09 »
Yes, perfectly possible, all the required signals are there.
You can use the wiring diagrams in the Haynes book of 'dangle berries' to work out what needs to go were, as it covers early/late MIDs (Hayne's idea of "late" is 1998/1999 models ;D)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #2 on: 22 July 2014, 06:57:58 »
Thank you for the answer:) do you also know if the newer type have less pixel problems?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 22 July 2014, 08:07:11 »
yea, newer type are more reliable in that sense.
Ive sent you a pm re more info.
« Reply #4 on: 22 July 2014, 08:07:35 »
They certainly appear to be much more reliable
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #5 on: 22 July 2014, 10:35:45 »
Big thanks to all you guys:) looks like its time to get a new type mid and a connector:)
« Reply #6 on: 22 July 2014, 17:39:38 »
Its very rare for the new type to fail.
What sort of radio, as I'm not sure if SC804 works with 10 digit radio output.
The MID has to be programmed to match the engine, gearbox, headlights, tyres and additional heaters fitted. Tech2 job.
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #7 on: 22 July 2014, 18:51:45 »
Radio is a pioneer aftermarket unit. With an interface to the omega display. Guess Im looking for the display numbered gm 90565934 /Opel nr 1236514?
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #8 on: 23 July 2014, 22:05:45 »
Just done this on my car, foolishly didn't take pictures for a how to but I will pm you how I did it and how I fixed the couple of issues I had.
Al
If it aint broken, you aint trying hard enough
« Reply #9 on: 25 July 2014, 09:49:20 »
Al
Post up the notes, maybe Monza can take a few pics, and we can do a guide :y
« Reply #10 on: 25 July 2014, 10:25:02 »
Al
This might help...
http://www.omegaowners.com/forum/index.php?topic=102703.0
Especially as you're essentially swapping pins from two plugs into one :-\ I used the 'later' Haynes diagrams for the pin numbers, you'll simply need to crossreference the 'early' Haynes diagram for the two plugs to swap the pins into the later plug :y
Should be an easy afternoons work... :y
