Author Topic: SatNav aerial  (Read 5425 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: SatNav aerial
« Reply #15 on: 24 July 2014, 10:05:08 »
VAG and GM often use different shape holes, one of them is square, and one of them is round - cannot remember which is which though
Black silicone is still the best fix if the aerial is working   :y
Radio & Decoding Technician
www.dndservices.co.uk
Phil
Re: SatNav aerial
« Reply #16 on: 25 July 2014, 10:38:42 »
Replacement rubbers are available, about £4 off ebay
Signum and Vectra C use the same base, so the whole thing can be swapped over if you get the aerial corrded into the base problem
Only issue is if you get a Vectra C one you need to cut the tube for the rear wash wipe off, Signum, and would guess Vectra C Saloons, don't have this issue
