Author Topic: auto box prob?  (Read 4489 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
Re: auto box prob?
« Reply #15 on: 27 July 2014, 16:42:05 »
just tried that this morn elmstoneboy , it worked a treat. :y
chrisgixer
Re: auto box prob?
« Reply #16 on: 27 July 2014, 18:40:41 »
yep my last omega hung in first for a while when cold,,,funny thing is i had oil and filter in box changed and it was worse only to find that the garage had not put enough fluid in when refilling the box...
If they filled it engine off, then it would be too low. Needs to be running, having selected a few gears. Preferably, check level with engine running, take it foe a short spin having engaged all gears and check again.
Likewise, if checking the oil level engine off, the oil will poor out of the level hole. Which you don't want, obviously. :)
chrisgixer
Re: auto box prob?
« Reply #17 on: 27 July 2014, 18:44:01 »
On the v engines it will hold a low gear until 3000rpm, or the cats are warm.
Or, until sport mode button or snow mode are pressed. However, if modes are turned off, and it's very cold, it sometimes goes back into cat warming mode.
Four pots might be slightly different...?
