Author Topic: Pollen filter part 2...Should I change it?  (Read 4283 times)
« on: 30 July 2014, 20:56:22 »
I've just checked the old invoices. It has been changed twice.
December 2007.........38,000 miles.
September 2009.........52,000 miles.
Car has now covered 88,500 miles. Does it need replacing?
The same garage changed it on both occasions yet only charged £7.25 each time. I wonder if they fitted the cheaper paper element instead of the carbon one?
Re: Pollen filter part 2...Should I change it?
« Reply #1 on: 30 July 2014, 20:58:35 »
30 second job to find out  :y
« Reply #2 on: 30 July 2014, 21:05:38 »
Where is it?......Do I access it through the glovebox?
I drive the 'superior' facelift model. ::) ::) ::) ;)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #3 on: 30 July 2014, 21:12:59 »
under scuttle pass side  :y
« Reply #4 on: 30 July 2014, 21:20:04 »
Thanks. :y
Why did I think that you can access it from the glovebox?..... ??? ??? ???
Steve B
  • Leicestershire
« Reply #5 on: 30 July 2014, 21:21:10 »
Thanks. :y
Pic 2   http://oldsite.omegaowners.com//forum/YaBB.pl?num=1167524083
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #6 on: 30 July 2014, 21:37:56 »
Thanks. :y
Dare I say it, old age. :P ::) ;D ;D ;D
flyer 0712
« Reply #7 on: 30 July 2014, 21:43:07 »
May be you were thinking of astra mk4 ???????     thats behind glove box.. :y
« Reply #8 on: 30 July 2014, 21:44:47 »
Thanks. :y
Oh how open you have left yourself, but I shall refrain from comment.............. :D :D :y
« Reply #9 on: 30 July 2014, 22:01:13 »
Yes...that must be it... ::) ::) ::) ;)
« Last Edit: 30 July 2014, 22:03:14 by Doctor Opti »
« Reply #10 on: 30 July 2014, 22:02:40 »
Thanks. :y
Well you would certainly know about advancing years, Mr Rods. ::) ;)
Keith ABS
  • Maldon Essex
« Reply #11 on: 31 July 2014, 07:44:24 »
The filter should be changed reguarly as it does get damp and is the biggest cause of the windscreen misting up by having damp air drawn through it
Keith B
« Reply #12 on: 31 July 2014, 10:29:36 »
What happens if you run the A/C without a pollen filter?
Our ancient Dyson DC01 has been running without filters for years and seem fine.
It is a noisy little bastard though, especially after 'Dysoning up' a load of concrete bits and dust.  ;D
« Last Edit: 31 July 2014, 10:31:26 by Doctor Opti »
« Reply #13 on: 31 July 2014, 10:38:27 »
Put a new filter in you tight bu66er!  ;D ;D ;D
« Reply #14 on: 31 July 2014, 11:22:11 »
If I was wealthy Mercedes owner and lived in  leafy Bury, I would. :y
Impoverished is how I would describe myself. ::) ::) :'( ;)
