Author Topic: Diff ratio  (Read 3949 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Diff ratio
« on: 31 July 2014, 09:56:50 »
Hi, is the Diff on an auto 3.2 MV6 the same as on the auto 3.2 Elite (estate and saloon) :y
Thanks for your help
Re: Diff ratio
« Reply #1 on: 31 July 2014, 10:16:55 »
Yep, they all had 3.9 diffs. :y
chrisgixer
Re: Diff ratio
« Reply #2 on: 31 July 2014, 10:49:19 »
Yep. All 3.9.
2.6 got 4.22, which gives slightly better acceleration if fitted to a 3.2, but slightly higher rpm at motorway speeds.
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Diff ratio
« Reply #3 on: 31 July 2014, 19:10:20 »
Thank you both :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Diff ratio
« Reply #4 on: 31 July 2014, 20:02:11 »
Got 3.7 fitted both my 3.2 Estate and Saloon.  ;)
chrisgixer
Re: Diff ratio
« Reply #5 on: 31 July 2014, 20:11:33 »
What is that like to drive Zirk?
Re: Diff ratio
« Reply #6 on: 31 July 2014, 22:10:27 »
Manual ;D
chrisgixer
Re: Diff ratio
« Reply #7 on: 31 July 2014, 22:12:39 »
Manual Edwardian ;D
Oh ffs. ;D
Re: Diff ratio
« Reply #8 on: 31 July 2014, 22:14:46 »
Pmsl ;D ;D ;D
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Diff ratio
« Reply #9 on: 31 July 2014, 22:29:15 »
They got you on that one Chris :y
Re: Diff ratio
« Reply #10 on: 31 July 2014, 22:39:41 »
did someone say something about manuals ::)
leaving the control to a 8 bit chip makes you what ? ;D
Re: Diff ratio
« Reply #11 on: 31 July 2014, 22:49:18 »
Munkay... ::)
zirk
  • Epping Forest
Re: Diff ratio
« Reply #12 on: 01 August 2014, 00:51:24 »
Sideways mostly if the LSD kicks in, but as pointed out once you get up to decent speed then its the same as yours but you have to move that stick around until you find one that works.  ;D ;)
zirk
  • Epping Forest
Re: Diff ratio
« Reply #13 on: 01 August 2014, 22:58:29 »
Although on a serious note, and being a Manual and assuming I can retian the LSD Clutch Plates, Im tempted to fit a 3.45 ratio and see how drivable that is and wether it will improve the 3.2's poor mpg figures.  :-\
chrisgixer
Re: Diff ratio
« Reply #14 on: 01 August 2014, 23:19:37 »
Where's 2woody? :-\
Suspect it will depend on the type of journey. If stop start in town perhaps an improvement as less time spent pressing the loud pedal.
If long run at motorway speeds, I'm not sure if the higher rpm will worsen mpg. Certainly on an auto, changing from a 3.9 to a 4.22 sees an increase of about 400rpm at 80mph. Which doesn't sound much, but can be slightly irritating.
It does go better and pull a higher top speed quicker. The 3.9 takes forever to get there. Your honour. :-\ ;D
