Author Topic: Faulty battery...faulty charging system...faulty connection?  (Read 13097 times)
Re: Faulty battery...faulty charging system...faulty connection?
« Reply #30 on: 01 August 2014, 10:36:05 »
Try it on another car that works properly and compare the voltages. :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #31 on: 01 August 2014, 10:37:25 »
All of those voltages look low to me.. which makes me wonder if your measuring device is accurate, TBH. :-\
It's a Gunson Sparktune, Kevin.
How can I tell if it's accurate or not?
By putting this across it ..And putting your hand in your pocket  :y
« Reply #32 on: 01 August 2014, 10:38:35 »
Can I borrow that when you've finished with it? I've got a printer issue. ::)
Steve B
  • Leicestershire
« Reply #33 on: 01 August 2014, 10:39:22 »
;D ;D ;D ;D
« Reply #34 on: 01 August 2014, 10:41:09 »
The family Corsa has a perfectly working 6 month old 50 A/H GM battery in it.
I'll try out the Sparktune on that. :y
« Reply #35 on: 01 August 2014, 10:53:46 »
That Kevin Wood fella could be right. :y
The Corsa shows..........10.8v without the engine running.
It also shows 12.9v at tickover and at 3000 RPM.
Virtually identical figures to the Omega.
Rotate the 'V' for voltage button slightly in a clockwise direction and the Sparktune will show anything you like  13.5v.......14v........15v. Less than 1mm of travel will change the reading completely. Hmmm.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #36 on: 01 August 2014, 10:55:56 »
It really does sound like a dead cell to me, with only 5 out of the 6 cells holding charge - hence the c.10 volts reading.
Ron.
« Reply #37 on: 01 August 2014, 10:57:51 »
Battery has not been disconnected but radio/CD player now showing 'SAFE'..... :-\
As Cem so eloquently put it, your battery is fubar  :y :y
I'm going to buy an electric car next. I won't have any problem with batteries then.... ::) ::) ::) :D ;D
 ;D ;D ;D ;D ;D :y
you better start exercising Opti.. you will have long times to push the car ;D
« Reply #38 on: 01 August 2014, 11:00:38 »
UPDATE........Car started 'relatively' easy this morning.
After 30 seconds I shut the engine down and then checked the battery voltage. Down to 10.8v.
Weird shit, man. :o :o
Battery now on charge again.
not worth it.. change it asap before it leaves you in the middle of nowhere :-\
« Reply #39 on: 01 August 2014, 11:03:40 »
Yep a little more than £50 notes will see a new battery land on your doorstep tomorrow(ish)!  :y
« Reply #40 on: 01 August 2014, 11:04:16 »
Ron.
If it were just the Omega I would tend to agree with you, Bigron.
But the battery on the Corsa also?.....
« Reply #41 on: 01 August 2014, 11:05:26 »
Two batteries if the one on the Corsa is also fooked. :).......(which it isn't)
« Reply #42 on: 01 August 2014, 11:11:06 »
Ron.
Exactly. Meter fubar. :y
Which makes me wonder what the omega problem is, then.
Have you checked the crimps where the cables join the battery terminals? Not getting hot when running?
« Reply #43 on: 01 August 2014, 11:13:52 »
Ron.
I shall check all battery connections again, Kevin.
Maybe a cable is breaking down internally. :y
Page created in 0.023 seconds with 16 queries.
