Author Topic: Door locking problem  (Read 5251 times)
powerslinky
« on: 02 August 2014, 17:58:56 »
Hi guys
Need your help on this
I have just met with new member Scorcher, he is struggling with posting at the moment so hope it's ok if I start this thread off for him  :)
His recently aquired car is a '51 plate manual 2.6 elite saloon.  There seems to be a few minor electrical issues starting with this door locking problem .
Locking wont work with the drivers door closed  . .  . open door  . .  locking works  . . .hold interior light button by door hinge in & locking works.
Any ideas where to start looking ?     TIA    Al  & Scorcher :y
powerslinky
Re: Door locking problem
« Reply #1 on: 02 August 2014, 18:23:51 »
Hi guys
Just to add to the above  . .  tried a locking re set  .  .that would not work.
Also all 4 doors lock if sitting in the car & pushing the drivers  door button down manually with door closed .
Also tried locking with the fob with the passenger door open  . . . nothing happens at all
Scorcha
  • Essex
    • Omega Elite 2.6 V6
« Reply #2 on: 02 August 2014, 20:34:56 »
Hi guys
If you hold the button in the locking DOESNT work
« Reply #3 on: 02 August 2014, 20:53:37 »
Using the fob?
powerslinky
« Reply #4 on: 02 August 2014, 21:03:20 »
Hi guys
My mistake   :-[. .  drivers  door open & interior light button held in & locking will NOT work with Fob
powerslinky
« Reply #5 on: 02 August 2014, 21:04:57 »
Using the fob?
Yes Rob  . .  using the Fob  . . . any ideas to help Scorcher ?
« Reply #6 on: 02 August 2014, 21:23:26 »
Have you tried swapping his driver`s doorswitch with a known good one (yours?)
powerslinky
« Reply #7 on: 02 August 2014, 21:31:22 »
No Rob not yet  . . . did not have much time this afternoon. But can try that next time I see Scorcher.
Have thought about pulling fuse No.7  & then trying then trying the fob . Do you think that may work ?
« Reply #8 on: 03 August 2014, 04:04:10 »
Sounds like a break/weak spot in the loom between the A post and the drivers door :-\
New drivers door loom probably as easy as repairing the break...
Scorcha
  • Essex
« Reply #9 on: 10 August 2014, 14:07:08 »
I have noticed on each of the front doors a red wire running alongside the rubber that goes between the door and the a pillar. Is is normal or could this be a previous repair?
« Reply #10 on: 10 August 2014, 15:19:19 »
There's a thin red plastic strip which is part of the plug assembly on the front door looms...
A pic would be handy :y
« Reply #11 on: 10 August 2014, 15:23:30 »
As you say Al, OP may mean this
« Reply #12 on: 10 August 2014, 15:42:10 »
Aye, that's the thingumyjig Rob :y
Though, I meant a pic from the OP to see what he's looking at ;D
« Reply #13 on: 10 August 2014, 16:09:12 »
I know what you meant Al. :y Thought my pic may help the OP
« Reply #14 on: 10 August 2014, 16:18:16 »
Anorak head on for a second, is that the passenger door :-\
Page created in 0.031 seconds with 20 queries.
