Pages: 1 [2] 3  All   Go Down
Author Topic: Tyre pressure monitoring....  (Read 6412 times)
Taxi_Driver
Re: Tyre pressure monitoring....
« Reply #15 on: 03 August 2014, 21:01:09 »
Lbs are old money TD ;)
Must be very old money, Chris. And i doubt the Insignia quotes its in 'old money'  :-\ ::)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #16 on: 03 August 2014, 22:06:04 »
PSI to you too ;D
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #17 on: 05 August 2014, 18:16:16 »
It drives me mad, only got to be 1 psi out and the blooming thing bleeps at you >:(
I used psi to keep Taxi Driver happy  :P
I like red cars
Taxi_Driver
« Reply #18 on: 05 August 2014, 18:37:57 »
 :y :y
Is yours a direct or indirect system?
relluf
« Reply #19 on: 05 August 2014, 19:42:43 »
Mine has valves on each tyre(colour specific)and if it loses more than a pound psi it shouts at you and the service light comes on and stays on until you rectify the darn thing.
Mainly a pain in the derrier,but I suppose quite useful, seems accurate too!
I won't mention the make cos I'll get no end of molestation and rude comments!!!!
« Reply #20 on: 05 August 2014, 22:17:06 »
 :y :y
Direct systems have a pressure/temp sensor per wheel to tell you a specific tyre is now only ??psi
Indirect systems that use the ABS reluctor rings and tell you to guess which wheel needs air  ;D ;D
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #21 on: 06 August 2014, 06:46:10 »
 :y :y
Direct system.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #22 on: 14 August 2014, 16:46:07 »
Since TD posted this, my tyre pressure monitoring system has been all over the place, even after a run it shows the incorrect tyre pressures, and constantly warns me that they are not equal on the same axle.
I blame Taxi Driver >:( ;)
I like red cars
« Reply #23 on: 14 August 2014, 16:50:19 »
It's all this driving at 45 MPH. You need to slow down a little so the tyres can cool off. ::)
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #24 on: 14 August 2014, 16:56:20 »
Ah, never thought of that :y
I like red cars
Taxi_Driver
« Reply #25 on: 15 August 2014, 06:56:00 »
S'not my fault  :o
Perhaps you should try filling them with nitrogen custard, to see if that helps maintain equal pressure  :)
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #26 on: 15 August 2014, 07:01:24 »
S'not my fault  :o
It is your fault for raising the thread, everything was fine till then ;)
Tyres - checked with 3 different gauges read :-
Front 32 Back 34.
Display read ( after a good run) Front 25 left 26 right, Back 29 left, 28 right.
So you see, it is your fault :D
I like red cars
« Reply #27 on: 15 August 2014, 07:18:25 »
Turn left less ::)
Simples :P
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #28 on: 15 August 2014, 07:29:50 »
Turn left less ::)
Simples :P
Never turn left, never have done.
I like red cars
« Reply #29 on: 15 August 2014, 07:32:27 »
Ah ok... stop driving along the cats eyes then :y
The right hand tyres are obviously experiencing extra loads, creating higher tyre temps leading to higher pressures. Doubtless Cem will be along shortly to explain why :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.029 seconds with 20 queries.
