Author Topic: Question for the Stag LPG Experts.  (Read 4359 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Question for the Stag LPG Experts.
« Reply #15 on: 04 August 2014, 17:47:44 »
The kme gold on my mv6 would randomly knock! At least I assumed it was that. What reducer are you running?
Same.
No idea mate,.......  I Meant Same, I knew that, same James, thanks for asking.
Same.  ;)
...and mine is, er, the same, as well.
Same ;)
Oh, except it doesn't knock. ;D
Aah, you have the Edwardian version type then. That's a shame... ;)
« Reply #16 on: 05 August 2014, 18:19:13 »
I'm still about... Very busy though ;)
The injector loom on that conversion has been soldered onto Vx Injector Plugs (the big grey one) and it's a pretty straightforward swap TBH. I also would budget on replacing all the pipe work though. Except, possibly, the fill pipe as IIRC it is a JIC type pipe.
zirk
  • Epping Forest
« Reply #17 on: 06 August 2014, 15:23:33 »
Thanks for the info LD on the injectors. Thinking about it there could be a plan B to this, in as much I have a BRC Front End kicking around, so could kinda source the rear end Dounut and bits and go fro there, although think about it the BRC is a Twin Vap design so more plumbing nightmares and is there room?
At least that way I can leave the existing MV6 Estate alone with its LPG and probably recoup some of the money Ive had to shell out on her when I sell.
OK any thoughts on the BRC System?
chrisgixer
« Reply #18 on: 06 August 2014, 15:44:31 »
Software? Diag lead? Useless without those unless its set up for the same engine, but even then you need to check its running correctly.
