Author Topic: MIG Welding Basics  (Read 4023 times)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: MIG Welding Basics
« Reply #15 on: 08 August 2014, 17:19:00 »
Yea. My sip has never missed a beat yet. I think its a great welder
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 08 August 2014, 21:59:36 »
Anyone know anything about this flux wire which means you don't hae to use gas?  :-\
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #17 on: 08 August 2014, 22:09:13 »
Never used it mate. Only flux i ever used was brazing copper pipes
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18 on: 08 August 2014, 22:21:06 »
Anyone know anything about this flux wire which means you don't have to use gas?  :-\
Don't bother, you end up with a poor mix of MIG and Arc, with few of the benefits of either. If you use a lot of it, then the extra cost works out about the same as proper wire(which is cheap if you buy full size reels) and gas.
Small cheap welders are best avoided; although they're capable of good work, they are very frustrating to learn on.
Having owned 3 SIP welders since 1989, I must agree with Mark in that they're not brilliant. The wire feed is poor, and inconsistent. I was reasonably pleased with mine until I tried a better machine which showed up why I was struggling occasionally.
The disposable cylinders are a terrible waste of money. They are expensive, unreliable, inconsistent and don't last long. If you can scrounge a CO2 cylinder and regulator, that will work, but if you have to pay for either go straight to a mix of 5% Argon/CO2 as it is much better. Pure Argon is only used for aluminium, and you won't be doing that with a small MIG. BOC are expensive, Hobbyweld are probably a better deal for limited use.
Webby the Bear
  • Northampton
« Reply #19 on: 08 August 2014, 22:25:10 »
Thanks Nick fir the info  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #20 on: 09 August 2014, 10:25:44 »
Ps guys, regarding the metal.... wheres the best place to get it? thinking b n q?
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #21 on: 09 August 2014, 10:42:05 »
Try
www.metalstore.co.uk
i got a 4ft x 4ft 1mm thick sheet delivered for about 16 quid
Webby the Bear
  • Northampton
« Reply #22 on: 09 August 2014, 10:43:41 »
Try
AWESOME! Thanks Davie  :y :y :y
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #23 on: 09 August 2014, 10:52:33 »
Sorry its called www.themetalstore.co.uk
chrisgixer
« Reply #24 on: 09 August 2014, 13:58:35 »
You'd be better off with a large gas cylinder type bottle. Most welding supplies places do an exchange service on the bottle. So while the initial cylinder us expensive. £50 odd. The next bottle should be much cheaper. I'll let you know how much when I've used mine up. It's lasting well so far.
  • Chatham, Kent
« Reply #25 on: 09 August 2014, 14:14:47 »
Remember to always turn off both the cylinder and the regulator. If you don't your cost savings go out the window, out the cracks in the roof and seep under the door.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #26 on: 09 August 2014, 14:33:34 »
The large hobbycraft bottle im using was £60 refundable on return of empty bottle plus £27 for gas. But once empty it costs £27 a time for a refill. Once i am finished with the bottle i get mu £60 back. Much better than £14 quid a time and bottle goes in the bin
