Author Topic: wet carpets ,,,,, again  (Read 4833 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
Re: wet carpets ,,,,, again
« Reply #15 on: 10 August 2014, 20:28:49 »
yes there not much room i sliced my arm in two places tryin to get my arm down to the bung just couldnt do it.
thats why i did from the other end and got hover in there. :y
tport
  • east mids
« Reply #16 on: 10 August 2014, 20:32:24 »
I had the same problem, driving through Friday's monsoon rains on the A428 in Cambriidgeshire.  The drain works but not for the rate of water that was pouring down the windscreen.  Had about two inches in the rear footwell wbich created a tsunami into the front footwell every time I slowed down.
peter the butcher
  • knaresborough, north yorkshire
  • omega driver as a hobby and now retired :-(
    • 2.6CDX
« Reply #17 on: 11 August 2014, 08:32:01 »
thats what happened to me.when I slowed down I exclaimed,,,, for F*&^%sake
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #18 on: 11 August 2014, 08:54:00 »
Is there some confusion here? I thought that the drain hole was part of the rubber bung take it  out completely and you have a large, inch and a quarter hole? which would allow the water to run straight out onto the chassis leg ,ie no obstruction atall. Does the bung over time get tired and the hole tend to close up?
mickyboy123
  • brighton
  • hi
« Reply #19 on: 11 August 2014, 09:09:36 »
yes the bung is the drain hole false stop, but unless you have matchstick arms you wont be able to get your arm in to remove it ;D  ;D
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #20 on: 11 August 2014, 09:21:22 »
If you are determined to remove it a long stick with a hook on the the end  or a piece of strong wire should get it out. An earlier post said take out the pollen filter carrier to get room I dont know what sort of job this is.
The DIRK
  • Reading
    • Omega Elite 3.0 Estate
« Reply #21 on: 12 August 2014, 20:46:43 »
I removed my pollen filter poked the dirt  out the small hole then washed it out with small amount of water to make sure it drained.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #22 on: 13 August 2014, 08:19:35 »
yes but needs doing on a regular basis depending on where car is parked,under trees etc.
peter the butcher
    • 2.6CDX
« Reply #23 on: 13 August 2014, 11:45:09 »
The lad at work who replaced discs and pads, said the chassis leg, were the water runs, was a very bad design fault, as the leg is as rusty as hell, and needs sorting, I have not seen it yet, but would have thought that a longer pipe would have sorted the problem when the car was designed, keeping the water away from the chassis, cause we all know what water and metal cause  :( :(
« Reply #24 on: 13 August 2014, 12:16:18 »
The leg itself is a very efficient drain :y
