Author Topic: Head skimming & 3L cams  (Read 2894 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 10 August 2014, 19:27:20 »
Hi ya,
Quick question.
I have two cylinder heads from my 2.5v6. I've removed valves as want them refurbed with new guides and stem seals (ALL guides are cracked from where the cambelt snapped).
Anyway, whilst having this done should I have them skimmed? Some say not to cos of the alteration to compression ratio.
Your thoughts welcome  :y
Oh and am I right in thinking that I can put 3L cam shafts in and not have to upgrade anything else???
RIP Paul Lovejoy
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: Head skimming & 3L cams
« Reply #1 on: 10 August 2014, 19:54:05 »
Get the heads skimmed to bring them true again, no problem in having them skimmed and don't worry about the compression ratio....
Fit the G cams, Iv done the same to my 2.5 V6 but you will lose some bottom end torque (as I have), it's not much of a problem unless - like me - you tow a big caravan around the country and you need the bottom end grunt to get you moving better...
D.I.L.L.I.G.A.F...
Webby the Bear
  • Northampton
« Reply #2 on: 10 August 2014, 20:20:48 »
Thanks MF...
Forgive my stupidity; what are G cams?  :-[
RIP Paul Lovejoy
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 10 August 2014, 20:31:12 »
Skimming heads is worth doing if it's necessary. Check with a decent straight edge, and if they're not warped(which they almost certainly aren't) leave well alone. V engines can be problematic if heavily skimmed, as the inlet manifold might not fit afterwards. A clean-up skim isn't going to make any worthwhile difference to the compression ratio.
Fitting new valve guides will require recutting the valve seats; with 24 of the things that's going to be expensive, and in my opinion, hard to justify.
Webby the Bear
  • Northampton
« Reply #4 on: 10 August 2014, 20:38:24 »
Thanks for the info Nick.
On that basis I may scrap them then. And if I decide to put the3L cams in do it on the current heads that are fine  :y
RIP Paul Lovejoy
minifreek
  • Wigan
« Reply #5 on: 10 August 2014, 20:43:19 »
The G cams are the 3 litre cams, fit 4 G cams for noticeable gains :)
OR
Fit 2 A cams on the exhausts and 2 G cams on the inlets as thats what they are anyway :) you will get gains and torque won't suffer...
D.I.L.L.I.G.A.F...
« Reply #6 on: 10 August 2014, 22:55:56 »
agreed..
and install 3.0 cams and a 3.0 ecu ;)
« Last Edit: 10 August 2014, 22:59:22 by cem »
minifreek
  • Wigan
« Reply #7 on: 10 August 2014, 23:02:18 »
Does the 3 litre ECU make a difference...?
Are they mapped differently to the 3.5's..?
D.I.L.L.I.G.A.F...
« Reply #8 on: 11 August 2014, 14:34:46 »
I'm using a vauxhall 3.0 ecu.. before was an opel 2.5.. maps are definitely different which is also shown on the same dyno..
Webby the Bear
  • Northampton
« Reply #9 on: 11 August 2014, 14:39:56 »
So upgrade to 3L cams and i'm going to need a 3.0L ECU too?
RIP Paul Lovejoy
« Reply #10 on: 11 August 2014, 14:45:42 »
Not necessarily... The cams will improve things on there own :y
The full list would be...
4 G cams
3.0 long plenum
2.6/3.2 exhaust manifolds
3.0 Ecu
Ecu can be chipped to good effect as well.
« Last Edit: 11 August 2014, 14:58:39 by Taxi Al »
« Reply #11 on: 11 August 2014, 14:55:03 »
nope..  only if you want a better pull :y
Webby the Bear
  • Northampton
« Reply #12 on: 11 August 2014, 14:56:02 »
4 G cams
3.0 long plenum
3.0 Ecu
Thanks Al,
i'll hunt for these G cams. When i want them (in the not too distant future) is an add on here the best way to get them?
RIP Paul Lovejoy
« Reply #13 on: 11 August 2014, 15:00:23 »
Zirk is/was flogging some :y
Webby the Bear
  • Northampton
« Reply #14 on: 11 August 2014, 15:03:07 »
Cheers mate  :y
RIP Paul Lovejoy
Page created in 0.034 seconds with 20 queries.
