Author Topic: caliper overhaul  (Read 4291 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: caliper overhaul
« Reply #15 on: 13 August 2014, 14:53:18 »
It's a really nice little project to do.
If the calipers are working (and you can push the piston back with ease) i'm not sure whether you can re-use the existing parts  :-\ but you will need to replace those things if the caliper is bound up.
It's a nice little project to do. i did some at college.
Note though you'll need compressed air to push the piston out. If not you can put a fitting in to the inlet and fill with grease til it pops out
keep ya fingers well away tho ;)
RIP Paul Lovejoy
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« Reply #16 on: 13 August 2014, 15:07:02 »
Taking them to work tomorrow to get them degreased and get fitter to drill out snapped bleed nipple... Doing a 4 on 4 off shift pattern gives me plenty of free time to do do stuff like this... Eases the boredom. :y
vauxsull
    • 3.0 Elite
« Reply #17 on: 14 August 2014, 13:01:40 »
Right then. £120 delivered gets me all the seals and pistons to do all calipers for a firm called "big red" is this a bargain of the century or do I look elsewhere?
« Reply #18 on: 14 August 2014, 16:06:43 »
The Omega callipers are bullet proof, if the dust seals are all ok then don't touch the workings as you risk resulting in a non working part with potentially inferior seals in it.
Just clean them up well and paint them.  :y
vauxsull
    • 3.0 Elite
« Reply #19 on: 14 August 2014, 16:13:44 »
Too late my friend.. All been stripped apart . Seals and pistons... One piston was goosed and 2 seals split... This is a spare set ive acquired and will clean up and rebuild as and when.. Just didn't know if the price for repair kit is a good price or not.
« Reply #20 on: 14 August 2014, 16:33:31 »
Sounds expensive to me to be honest!
If the dust seals were ok then the damage will have been done in disassembly I suspect.
vauxsull
    • 3.0 Elite
« Reply #21 on: 14 August 2014, 16:34:40 »
They where disassembled because of the damage not due to.
Webby the Bear
  • Northampton
« Reply #22 on: 14 August 2014, 17:18:57 »
I still maintain it's a nice project (what the OP said he wanted to do in his first post) and something you can be proud of :)
£120 does sound a tad expensive. Were there any other kits available? Having said that a brand new calliper is just over £100 so after doing the work you get 4 new callipers + sense of satisfaction for doing it  :y
Note that when the square cut seal's removed there'll be a bunch of rust in the groove where it lives. Be sure to also nail that with a wire brush otherwise that'll be as bad as using the rusty old pistons.
Ps..... photos of the project would be great  :y :y :y
RIP Paul Lovejoy
vauxsull
    • 3.0 Elite
« Reply #23 on: 14 August 2014, 18:12:04 »
If i knew how to upload images on here I would have dome ir ages ago  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #24 on: 14 August 2014, 21:24:39 »
That is expensive for two sets of seals and pistons, you should be able to get 2 exchange calipers for £120.
Seal kits from biggred are normally about £20 per caliper, I've yet to replace a piston, normally just polish them up with autosol polish.
Hoof'land storeman.
vauxsull
    • 3.0 Elite
« Reply #25 on: 15 August 2014, 05:19:49 »
That price was for a repair kit for 4 calipers
biggriffin
« Reply #26 on: 15 August 2014, 08:34:53 »
That sounds better£120 for all 4 callipers.
Hoof'land storeman.
vauxsull
    • 3.0 Elite
« Reply #27 on: 15 August 2014, 08:55:47 »
I shall buy them then... Never done this job before so had no idea on costs.. :y
