Author Topic: Rear track rods.  (Read 3533 times)
ted_one
Rear track rods.
« on: 13 August 2014, 16:43:13 »
I'm looking for some info from your good selves as I need four new rear track rods so that I can get the rest of the wheel alignments done.The last set came from AllGermanparts but they are out of stock and I've been let down by another supplier.So has anyone got any ideas apart from VX where I can start looking as I've had no luck so far.
Re: Rear track rods.
« Reply #1 on: 13 August 2014, 16:45:46 »
Give Steve a shout at Omegaspareparts and butter up the local engineering firms :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #2 on: 13 August 2014, 16:53:00 »
Are the ones you have got sloppy, or merely rusted solid? If the latter, they can usually be freed with heat and patience.
ted_one
« Reply #3 on: 13 August 2014, 17:32:12 »
Badly corroded I'm afraid,both cars been turned away by ATS,they spent nearly an hour trying to free them up and in the end they had to give up.Last car I took in last month had a duff bush and so replaced both track rods to save it from an Mot fail in a couple of months time. Not happy to frigg around with s/hand as Omegaspareparts want £35 for a single and I only paid £54 for new Lemforders from Allgerman. :-\
« Reply #4 on: 13 August 2014, 17:39:37 »
Ring Steve and speak to him :y
Failing that, try my preferred German supplier of suspension gubbins... atp on ebay.de :y
ted_one
« Reply #5 on: 13 August 2014, 17:45:10 »
I've just had a delivery of two sets of front track rods and drop links from ATP ...they are good for these and wishbones but unfortunately they don't stock the rears. :(
« Reply #6 on: 13 August 2014, 17:51:16 »
Pm incoming :y I have seen them listed...
chrisgixer
« Reply #7 on: 13 August 2014, 19:07:23 »
I wonder is it worth fitting some sort of gator over these before fitting to the car?
Bicycle inner tube or sumat, over a heavily greased track rod?
Needs to breath though or there will be condensation and, more rust.
ted_one
« Reply #8 on: 13 August 2014, 19:20:19 »
For definite..this is a pain in the arse,have now found some Lemforders in Germany (thanks Al)  Have already done the fronts in the past few months and they are already seized up solid..going to give up on the Omegas soon....real old money pits ::)
« Reply #9 on: 13 August 2014, 19:45:18 »
Found these at ATP... https://www.atp-autoteile.de/group/503011/product/15808/110325/details.htm only one half though :-\
Not found any Cadillac ones on ebay.com either :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #10 on: 13 August 2014, 20:55:57 »
The front track rods should not seize up in months. Take them off the car, and they will yield, using heat if necessary. Dismantle them, wire brush the threads, and reassemble with copper ease grease. I only discard track rods when the joints are gone, or maybe the gaiters. Buying new is easy, but then your Omega will eat money.
« Reply #11 on: 13 August 2014, 21:31:27 »
I have a set to go on TBE that's sat in my hallway (bit too much heat applied last time (and brute force when still hot), they said it was unlikely to take more abuse).
From dealer, I'm afraid (due to my current doubts with Lemforder stuff), £90 each :o
chrisgixer
« Reply #12 on: 14 August 2014, 00:28:58 »
Delphi front tre's on mine. No issues so far. Despite their appalling track record with omega wishbones.
Not sure if they do rears, as an after thought. :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #13 on: 15 August 2014, 22:22:40 »
Hoof'land storeman.
chrisgixer
« Reply #14 on: 15 August 2014, 22:36:48 »
www.vauxhall-car-parts.co.uk
Ah yes, I can see a pattern forming, again.
It's quite a familiar pattern, buy aftermarket quality, buy oe quality about 3months later.
Page created in 0.032 seconds with 20 queries.
