bathroom silcone sealant
Started by tidla, 13 August 2014, 19:42:59
tidla
The shower in my house is well used. Refitted in 2010 and had to change the sealant twice already because of black mold.
I have used so called quality sealants with a 10+ guarantee to no avail.
Is there any trade recommendations for a quality sealant product which wont go moldy.
Price is not a problem, as i can use the remainder on some cam cover gaskets. (runs and hides)
Thanks.
Use the black VX cam cover goo, then you won't see the mould!  :y
4x4
Dow corning 785, white mastic sealant,can get it from any builders merchants,its good but you have to be quick using it.
r1
why not claim on the 10year guarantee? ;D ;D
I'm saying nothing, as Mrs TB reapplying sealent has ended up with a cracked shower tray.  Only being Betamax man, it looks like its a non standard sized tray. 'dangle berries'.
kevinp58
Forever white you can get it at most decent plumbing supplies I use it all the time and haven't had any problems.  :y :y
Taxi_Driver
Quote from: tidla on 13 August 2014, 19:42:59
Thanks.
Try mould and mildew remover.....i use it now and again....spray it on, leave it to do it work...and the black mould disappears...then rinse off  :y
Rog
Quote from: Taxi Driver on 14 August 2014, 06:02:03
Thanks.
. . . . . .  also DO NOT close the shower doors when not in use, leave open. This completely sorted the problem for us.
Phil
What you need is a low modulus silicone sealent that, preferably has a fungicide in it.
Pretty much anything external and non marine (as in fish tank) use is good. Needs to be low modulus due to the movement
I use ArboSil 1096, made by Adshead Ratcliffe 15 years and no mould in my bathroom so far. Its designed for bonding glass to glass in curtain wall and perimeter seals (so I get it free), has lots of flexability and good adhesion thats why it doesn't peel off surfaces like other silicones over time. Really easy to tool off as well
Far better than Dow 791, if you do go Dow then get 995 which is their alternative to 1096
Have you tried cleaning more than once a year?  :P ;D
chrisgixer
 Most damp, mildew or mould issues are sorted with ventilation ime. Leave the shower door open as said, fit a good humidistat extractor fan, and open windows as soon as is practical after shower use.
Unrelated after thought, that karcher window vac is good for removing moisture from glass shower panels, mirrors and tiles etc. Keeps water marks to an absolute minimum, even with a water softener, and in this instance, maybe it will keep moisture down in the unit itself..?
X30XE
Generally avoid anything that describes itself as a "sealant".  Anything you could possibly buy in B&Q/Homebase is junk. Get a trade low mod silicone.
Thin bleach sprayed on and left is fairly effective at killing black mold and keeping grout and silicone white.  :y
Omegatitis : [in remission]
tigers_gonads
Quote from: 4x4 on 13 August 2014, 20:46:18
Use this myself, but as said it goes off very quickly  :y
Quote from: TheBoy on 13 August 2014, 21:35:54
What was she applying it with? Sammy? :o
Auto Addict
I use Auto Glym caravan black streak remover to clean around the edges of the shower basin, mould doesn't get a chance to build up.
I like red cars
