Author Topic: Bose. Ncdc 2015. No front speakers.  (Read 5770 times)
chrisgixer
Re: Bose. Ncdc 2015. No front speakers.
« Reply #15 on: 20 August 2014, 23:14:40 »
Hooks in one end IIRC
 I have a vague recollection of something going ping when I undid it, in order to remove the Bose shelf. :(
« Reply #16 on: 21 August 2014, 00:24:52 »
A string of cable ties around the amp, running through the wires as they exit the plug. Should hold it securely in place :y
chrisgixer
« Reply #17 on: 21 August 2014, 00:32:30 »
Hay hay hay! This is an Elite we're talking about. Elites don't do twigs and bailing twine, or gaffer tape and cable ties to hold the universe together! Oh no!
Elites have the proper part replaced. [posh voice on] don't ya know [posh voice off]
....unless its a right pita or very expensive of course, then "alternative arrangement" MIGHT be sort. Young man! A cable tie indeed HAH ::)
;D ;D ;D   ;) :y
« Reply #18 on: 21 August 2014, 00:35:37 »
If it stops it coming undone every time you hoon it around corner gently... ::)
chrisgixer
« Reply #19 on: 21 August 2014, 00:44:06 »
Ah, but its how its hooned. There's hooning, and there's hooning. A tweaked Elite hoones, rather than hoones. Obviously. ;) ;D
No I've no idea what I'm on about either ;D
« Reply #20 on: 21 August 2014, 00:45:35 »
Just pop some cable ties around it and it won't fall out, no matter how slowly you drive :y
chrisgixer
« Reply #21 on: 21 August 2014, 00:48:28 »
I'd rather fix the clip. Probably not possible without un picking all those pins though. :(
« Reply #22 on: 21 August 2014, 00:51:21 »
Think of it as an alternative solution rather than a bodge :y afterall, it's not like you can see it...
« Reply #23 on: 21 August 2014, 18:14:41 »
I think you may change your mind and resort to cable tied, or tiny blob of glue.
