Author Topic: Leisure battery ?  (Read 4948 times)
Re: Leisure battery ?
« Reply #15 on: 20 August 2014, 10:02:30 »
Lets start again  :D ;D
I need a leisure battery .. yes
The car is wired up to charge the leisure battery .. yes
So all i need is a leisure battery ?  :-\
Sorry for not understanding  ;)
« Reply #16 on: 20 August 2014, 10:06:02 »
Yes.
Assuming the mains hook up provides 240v and charges your leisure battery when it's not connected to the car :y
« Reply #17 on: 20 August 2014, 10:07:12 »
Yes.
Why does the mains have to charge the battery if using the mains  ???
« Last Edit: 20 August 2014, 10:10:28 by Emd »
« Reply #18 on: 20 August 2014, 10:12:25 »
Yes to all of the above.
You don't need a caravan to have need for an inverter. They are a nice to have item if you want to watch a mains telly in the back seat of your car or power a laptop etc http://www.maplin.co.uk/search?text=inverter&x=0&y=0 The bigger the inverter  the bigger the draw on your leisure battery  ;)
« Reply #19 on: 20 August 2014, 10:13:53 »
Yes.
because there are things in the caravan that are powered by 12 volts eg the water pump & most/all of your lighting
« Reply #20 on: 20 August 2014, 10:15:28 »
In that case you would only need an inverter if you want to camp at random in the sticks. If you get an inverter you would need a second leisure battery and if camping at random alot, then you would need to do a few miles between stops to keep the batteries topped up from the car.
Sounds like you only intend to camp on sites though, so an inverter is probably an extravagance :y
« Reply #21 on: 20 August 2014, 10:19:04 »
Yes.
So when i plug in the blue lead from the van to the house its converting 240v to 12v .
And the 240v to 12v also charges the battery  :y
 ;) :y
« Reply #22 on: 20 August 2014, 10:22:07 »
Ah! You confused me there, the mains hook up lead is normally orange ........ but if yours is blue, then yes
And the 240v to 12v also charges the battery  :y ...
Yes.  :y
« Reply #23 on: 20 August 2014, 10:24:03 »
Yes.  :y
Im confused now , i'll have to go and check  ;D ;D ;D ;)
You were right andy , its orange  :-[
Ill get the 12V 100AH  battery  ;)
« Last Edit: 20 August 2014, 10:31:25 by Emd »
« Reply #24 on: 20 August 2014, 10:51:50 »
No wonder you're having problems with electrickery if you can't tell orange from blue!  ;D ;D
Blue IIRC is the colour of the cable in the 12S plug/socket for caravan battery charging  :y
« Reply #25 on: 20 August 2014, 19:13:13 »
I opened the front storage box and found the battery terminals , ah thats where they are kept  ::) :-[ Because there will be no gas bottles it leaves quite a nice storage area .
« Reply #26 on: 20 August 2014, 19:39:42 »
I opened the front storage box and ..... it leaves quite a nice storage area .
Don't put too much in there, remember your caravan's nose weight should be nor more than the max weight for the Omega's tow ball ie 75 kg
I had my arms calibrated  ::) such that if I could lift the tow hitch, then I was about right  :y but technically you should use a nose weight gauge or a set of bathroom scales  ;)
« Reply #27 on: 20 August 2014, 19:44:43 »
Aye but ive lost a fare bit of weight ditching 2 gas bottles  ;)
