Author Topic: Car isn't level lol  (Read 11089 times)
Re: Car isn't level lol
« Reply #15 on: 21 August 2014, 17:19:45 »
Might have lost the last inch or so off that coil, but not recently from what little detail visible in the second pick :-\
« Reply #16 on: 21 August 2014, 23:16:37 »
Looks broken to me Webby - bottom bit missing - bottom coil should be tapered, not square ;)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 22 August 2014, 00:42:51 »
Thanks lads. it looks broken to me too! lol
Went for 30 mile round trip tonight. It really is leaning on right hand turns, round abouts etc. and there's definite creaking!
As Al says, if it is broken it doesn't look recent. But perhaps the fitting of the new shocks has highlighted the problem......?
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #18 on: 22 August 2014, 00:43:11 »
Ps, any other opinions on the pics?
RIP Paul Lovejoy
« Reply #19 on: 22 August 2014, 01:29:22 »
Not enough totty ::)
« Reply #20 on: 22 August 2014, 01:35:42 »
To be sure, measure the distance from the spring seat on the trailing arm and the spring seat on the chassis rail...
Repeat on tother side and compare  :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #21 on: 22 August 2014, 07:18:20 »
Looks broken to me, the jagged end is typical of a fracture. New springs either have square ends or ends ground to a tapered end that sits flat. The bottom end of the spring, les than one coil, has broken off and disappeared.
Webby the Bear
  • Northampton
« Reply #22 on: 22 August 2014, 10:21:06 »
Exactly what I was thinking senor Al  :y :y :y :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #23 on: 22 August 2014, 10:21:41 »
Thanks Tel  :y :y :y :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #24 on: 22 August 2014, 13:12:47 »
ooooooooooooooooooooooooook
went out and measured...... both 25cm in length rom chassis to trailing arm  ??? ??? ???
xxxxx
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #25 on: 22 August 2014, 13:12:59 »
now what? lol
RIP Paul Lovejoy
« Reply #26 on: 22 August 2014, 13:18:58 »
I wonder if the subframe bush has failed?  :-\  I don't know much about these so I'm probably talking out my 'arris!  ::)
I've noticed that I have the same issue so I'm off out this afternoon to investigate!  :(
Webby the Bear
  • Northampton
« Reply #27 on: 22 August 2014, 13:21:37 »
The subframe bush being the ''donuts'' under the triangular plate????
RIP Paul Lovejoy
« Reply #28 on: 22 August 2014, 13:33:36 »
That's the one!  :y  I'm sure Gixer will be along soon to dish out some abuse advice!  ;)  ;D
  • Auckland
    • Mazda MPV
« Reply #29 on: 22 August 2014, 13:37:39 »
Whether the end is tapered or not depends on the vehicle spec - OE self levelling will probably be tapered - anything else will probably be equal diameter to the bitter end.
Unbroken springs are a snug fit on the rubber cup. If the spring slops about then the end has broken off  :(
Pages: 1 [2] 3 4  All   Go Up
