Author Topic: Loss of radio signal when heated rear window is on  (Read 3338 times)
mantamania
  • Chatham, Kent
    • 2.6 Elite
« on: 21 August 2014, 15:50:50 »
Dear all,
I have a 2.6 Omega Elite which looses its radio signal when i turn on the heated rear window. I am not sure where to start looking for the problem
Re: Loss of radio signal when heated rear window is on
« Reply #1 on: 21 August 2014, 16:05:47 »
The screen heater element is the aerial, (assuming it's a Saloon)... I would start with the aerial amp which will be under the parcel shelf somewhere. Might be accessible from the boot :-\
Looking for a loose or broken connection there :y
« Reply #2 on: 21 August 2014, 16:05:55 »
Dear all,
Connections to the amplifier under the parcel shelf ....... I just didn't turn the HRW on  :(
« Reply #3 on: 21 August 2014, 16:06:58 »
...... Might be accessible from the boot :-\
Unfortunately it's on the steel shelf under the cover.
mantamania
  • Chatham, Kent
    • 2.6 Elite
« Reply #4 on: 21 August 2014, 16:14:16 »
Thanks, i will have a look on Saturday
« Reply #5 on: 21 August 2014, 18:16:46 »
Look for poor 0v connections. Or the Earths if Mr DTM isn't listening ::) (yes, I know he's technically correct ;D)
Also, first, try cleaning the inside of the rear window, gently.
« Reply #6 on: 21 August 2014, 18:30:17 »
.... (yes, I know he's technically correct ;D)
But we're not technical  ;)
Though not as much as it was in the Omega, there's some interference on the radio in my Merc if I put the HRW on  ???
    • 530D M Sport, 330i Coupe
« Reply #7 on: 21 August 2014, 19:01:11 »
That usually fixes this problem in my experience  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #8 on: 30 August 2014, 13:35:27 »
Does it will give that ago  :y
To get at that amp you will have to have rear seats out too. Just like doing a rear blind :y Which ive got to go and do all again cos the bleeding thing is jammed up   :'(
« Last Edit: 30 August 2014, 13:37:10 by BIGtime »
« Reply #9 on: 30 August 2014, 13:45:30 »
Indeed you do... so while you're in there.. ::)
