Author Topic: v6 water leak  (Read 4678 times)
steve6367
v6 water leak
« on: 24 August 2014, 09:49:34 »
So car went really well to Yorkshire and back after changing thermostat and cam covers gaskets. Yesterday had to go to London and almost home the aux belt starts screeching.
When looking in the dark at 2am front of engine, alternator, belt all wet with coolant and header bottle half empty.
Any normal causes in that area? Water pump?
Steve
Re: v6 water leak
« Reply #1 on: 24 August 2014, 10:00:51 »
Given the work you have had done, retrace your steps around the stat.
steve6367
Re: v6 water leak
« Reply #2 on: 24 August 2014, 10:02:34 »
That's today's job the - strip the top down again   >:(
steve6367
Re: v6 water leak
« Reply #3 on: 24 August 2014, 12:09:08 »
V looks dry, but see below  :D - failed rad?
steve6367
Re: v6 water leak
« Reply #4 on: 24 August 2014, 13:21:39 »
Aux belt very slack also and had almost worked its way off the centre pulley.....
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: v6 water leak
« Reply #5 on: 24 August 2014, 15:56:12 »
I dont know why but shortly after a thermostat and water pump replacement my rad had a tiny leak,Extra pressure from pump?
Re: v6 water leak
« Reply #6 on: 24 August 2014, 17:11:41 »
That will be why then  ;D
Re: v6 water leak
« Reply #7 on: 24 August 2014, 21:11:16 »
Hard to tell if that is rad or condenser losing its bits. But have you defo identified the leak, and its not from the red tap seal?
steve6367
Re: v6 water leak
« Reply #8 on: 24 August 2014, 21:28:39 »
No, not confident at all at this stage. There was no water around the stat area but then it could have dried out with engine heat I imagine.
I think I need to remove the rad, or at least strip enough away to get a really good look.
What I don't understand is why the belt is so slack and how that relates to the water leak.
Time was limited today, but should be able to get back to it tomorrow.
Steve
steve6367
Re: v6 water leak
« Reply #9 on: 24 August 2014, 21:29:49 »
I clearly had to use that when I did the stat, so will double check.
steve6367
Re: v6 water leak
« Reply #10 on: 24 August 2014, 21:31:40 »
One final thought it that the black plastic part in the photo was laying with the bits - I don't know what it is but wonder if it came away, got caught in the fan and damaged the rad that way.....
Re: v6 water leak
« Reply #11 on: 24 August 2014, 21:35:38 »
Looks like plastic shroud around egr socket
Re: v6 water leak
« Reply #12 on: 24 August 2014, 23:40:13 »
Yep , maybe wasn't connected and wire got caught in belt  :(
Re: v6 water leak
« Reply #13 on: 25 August 2014, 00:07:26 »
Was the belt routed correctly?  Should be tighter than a ducks plughole, relatively speaking... Unless the tensioner has failed :-\
steve6367
Re: v6 water leak
« Reply #14 on: 25 August 2014, 15:06:49 »
So the tensioner is working but at the end of its travel. The large flat pulley centre of the engine is flapping around all over the place however. The bolts I can see holding the pulley on are tight but the whole assembly is easily moved around by hand.
What is this pulley?
Steve
