Author Topic: Radiator sensor refitting  (Read 1776 times)
    • 530D M Sport, 330i Coupe
« on: 26 August 2014, 16:07:03 »
Bit of a dumb question really!
Going to reuse the sensors off my radiator on my new radiator on the 2.6, presumably a clean up of the copper washer with some fine emery paper would be advisable? or do I just replace the washers?
NB. Sensors are fine - not had an oil cooler failure, just a leaking radiator.  :y
Re: Radiator sensor refitting
« Reply #1 on: 26 August 2014, 16:16:57 »
Re-anneal it if you can and re-fit, you could put a wipe of liquid PTFE on the threads or a couple of turns of PTFE tape if you want.
chrisgixer
« Reply #2 on: 26 August 2014, 21:17:14 »
Encountered 3 gm facelift omega radiators in the lest week or so, and each one had Dowty washers behind the sensors. Just did. :)
  • Auckland
    • Mazda MPV
« Reply #3 on: 26 August 2014, 21:46:15 »
When I changed my radiator the copper washers appeared to seat on the plastic of the header tank.
I didn't bother annealing the washers I just wiped them clean and used a smear of Blue Hylomar to help with the seal.
It seems to have worked. Magical stuff Hylomar, I used to get through loads of the stuff when I used old British motorbikes as daily transport  ;)
