Author Topic: Air Con Low Pressure Valve - Part Number ??????  (Read 6462 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Air Con Low Pressure Valve - Part Number ??????
« Reply #15 on: 03 September 2014, 16:35:16 »
Okay I received the GM A/C low pressure valves along with the cheap red ones..
The GM ones on the right don't fit, The Left red one was the same type removed from the car so I presume it's safe to put a new one of them in.  :-\
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #16 on: 03 September 2014, 17:50:24 »
Hummm.  My "GM" ones also arrived and same as the ones on the right in your PIC !!!
Where did you get the red ones from ? as I obviously need one of them (or may not as :D as  not checkd a/c since re-gas at  weekend !!
Cheers,
Andy.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #17 on: 03 September 2014, 17:57:56 »
Post #4 I put a link to the red ones  :y
DrAndyB
  • Neston / Cheshire
« Reply #18 on: 03 September 2014, 18:32:27 »
 :y :y :y  I shall order some of them as well then  >:( >:( >:(
