Author Topic: Jaguar S Type V8  (Read 8536 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Jaguar S Type V8
« Reply #15 on: 04 September 2014, 21:06:57 »
As said timing chains/tensioners a weak point.Ideally you want to see evidence that these have been changed for the uprated 4.2 litre ones.First tensioners were plastic which fell apart,Jaguar changed them later for plastic/metal ones,which fell apart.Percieved wisdom is that any engine with the Nicasil linings that has lasted thus far should be o.k.-it was the high sulphur content in the petrol at the time that caused the wear.Gearboxes I believe are the sealed for life type-they certainly were on the XJ from '97 on.I have also heard that the thermostat tower[plastic again]can get brittle with age and leak,alloy ones are available from the U.S.A.
Manual Elite V6
  • Swansea
  • Mechanic and MOT tester at a Jaguar specialist.
    • 1992 Cavalier GSi
« Reply #16 on: 04 September 2014, 21:48:59 »
Most of the later gearboxes are said to be sealed for life but the oil can still be changed anytime you like, just like any other box, just make sure LT ATF goes in.
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
« Reply #17 on: 05 September 2014, 18:19:30 »
The S type has very, very light, over assisted steering. It does take quite some getting used to.
« Reply #18 on: 14 September 2014, 21:01:06 »
Picked it up on Saturday and l'm very pleased with it, lots of car for the money just like the elite. One thing I will be changing is the exhaust, it stifles the sound of the V8 ::) ::)
« Reply #19 on: 14 September 2014, 21:11:33 »
Nice motor, Pete.
I always liked the looks of the S Type. :y
« Reply #20 on: 14 September 2014, 21:30:49 »
Nice motor, Pete.
Dirt cheap as well ;)
« Reply #21 on: 14 September 2014, 21:39:34 »
Nice motor, Pete.
How dirt cheap? The supercharged version has it's appeal. :y
The Sheriff
« Reply #22 on: 14 September 2014, 21:43:39 »
Chav.
« Reply #23 on: 16 September 2014, 06:59:40 »
Nice motor, Pete.
Mine is a 01 S-Type with 80000 miles and I paid £1000 with 12 months not and 4 months tax. The STR will cost you quite a bit more but I've started saving :)
« Reply #24 on: 16 September 2014, 07:00:27 »
Chav.
Yep, it's because I live so close to Liverpool :P ;D
« Reply #25 on: 16 September 2014, 12:43:19 »
Chav.
calm down.......calm down......calm down. ;D ;D
