Pages: [1] 2 3  All   Go Down
Author Topic: W reg vw passat. This is turbo issue right?  (Read 6755 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 08 September 2014, 18:55:02 »
Sup fellas  :y
So wife's dad got the above car. Hardly any power in any gear. I'm thinking the turbo snack erred or most likely the waste gate has stuck open.
My theory right and if so how do you test such things? I learned the theory in school but I've never had to get to one.
Any help greatly appreciated  :y
RIP Paul Lovejoy
4x4
Re: W reg vw passat. This is turbo issue right?
« Reply #1 on: 08 September 2014, 19:10:12 »
Have a look at turbo,there should be a rod going across it to a flap,if its open you will feel the gap,or remove a pipe and see if the vanes spin freely,as it could be seized,if it has seized you need to find out why,also if it is a new turbo job,do oil and filter change.
Webby the Bear
  • Northampton
« Reply #2 on: 08 September 2014, 20:23:25 »
Thanks martin/
don't suppose you got a piccie? I take it if it is the turbo its a simple remove / replace job?
RIP Paul Lovejoy
4x4
« Reply #3 on: 08 September 2014, 20:27:56 »
No i havnt mate,have you looked on autodate?
tidla
  • solihull
« Reply #4 on: 08 September 2014, 20:36:19 »
You need to check the the vac hoses first.
With limited tools the only thing you can really check is as mentioned that the turbo vanes spins freely. Touch the shaft not the vanes.
Diagnostics can test the turbo actuator electronic box which actuates the vacuum feed.
Any codes with your new toy? (n57 valve)
The turbo variable vane movement and associated pipework can be tested is you can get your hands on a vac gauge.
Split/ rubbed hoses cause issues.
tidla
  • solihull
« Reply #5 on: 08 September 2014, 20:37:47 »
Engine code/ diesel?
serek
  • huntingdon
    • 3.2 mv6
« Reply #6 on: 08 September 2014, 21:36:36 »
Did you check fault codes ? As Other say check vac pipes
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #7 on: 08 September 2014, 22:11:40 »
+1 on checking vac pipes,is this the old tdi lump or the later Pd lump?,engine code?
other rides
henryd
  • west cornwall
« Reply #8 on: 08 September 2014, 22:14:39 »
Don't assume turbo just because it won't go,many other things can cause the problem,maf being one of them and they rarely throw up a code for it .
other rides
Webby the Bear
  • Northampton
« Reply #9 on: 09 September 2014, 09:50:56 »
Thanks boyos :)
Sorry, yeah shoulda mentioned..... Passat 1.8 TDI on a 2000 plate :)
So, i'll check vac pipes going to and from turbo. ill see if theres any codes. and i presume the inlet connects in someway to the turbo so i can remove this and spin turbo by hand?
RIP Paul Lovejoy
« Reply #10 on: 09 September 2014, 10:20:19 »
Plenty of things can cause lack of boost including the likes of a stuck open EGR valve etc.
Webby the Bear
  • Northampton
« Reply #11 on: 09 September 2014, 11:23:32 »
Thanks mark,
anyone familiar with this engine and possibly have pics of the wastegate, pipes, turbo, egr valve etc. im just a bit scared as never even held a turbo before lol
RIP Paul Lovejoy
« Reply #12 on: 09 September 2014, 11:51:58 »
Well we still don't know which engine it is, it could be the old 8V direct injection diesel or the PD given the age.
And there may well not be a waste gate either.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #13 on: 09 September 2014, 12:34:32 »
Check the hose hasn't popped off the turbo, happens quite a bit and can lead to a diagnostic tail chase if not checked first :y
henryd
  • west cornwall
« Reply #14 on: 09 September 2014, 12:53:03 »
Thanks boyos :)
It won't be a 1.8 unless its petrol powered,diesel is 1.9 unless its the v6 :y,engine code is written on a label on top cam belt cover and under boot carpet on a stuck on paper label
other rides
Pages: [1] 2 3  All   Go Up
