Garage Charges
Started by Mr Skrunts, 11 September 2014, 19:05:43
Having read the symptoms I'm not convinced it's a hg issue at all :)
Where are you located? :y
Quote from: JamesV6CDX on 16 September 2014, 11:27:15
Am near M18 J1 and M1 J31 Edge of Rotherham/Sheffied
Moved the car off the the road today as I realised the MOT has just run out.  Struggled to start the car with jump leads, did get it running in the end but a lot of light gray smoke from the exhaust with a smeel of petrol as well. :-\
Quote from: Mr Skrunts on 16 September 2014, 19:31:17
Both normal when cold... :y
Quote from: Doesn't play well with others... on 16 September 2014, 19:36:30
The smoke isnt on that car, often smelt petrol on start up, but never ever seen smoke like this.
How long has it been stood for?
Quote from: Doesn't play well with others... on 16 September 2014, 19:55:34
Parked it up on road in jan, started and moved it no probs as it was cold with a fresh battery about 6 weeks ago, turned it round drove it backwards and forwards 3/4 times and parked it up again.
Then again today, but battery flat again, struggled a bit to jump staet but got there after a while, then parked it up on my drive.
Broomies Mate
To be fair, the V6 takes a bit of starting if using anything other than heavy duty jump leads, especially if the battery is very flat.
Quote from: Broomies Mate on 16 September 2014, 23:07:09
Very true, but this is this first time I have ever struggled with it, normally 1st turn of key even after about 30 seconds of jumper leads going on (but thats with a healthy engine.
Was the engine tested as being watertight after the freezing incident?
Mine smoked quite a bit after being stood for a couple of months, been fine since, so think the smoke is a red herring...
