Pages: [1] 2 3 4 5   Go Down
Author Topic: Stupid kick-down question.  (Read 13619 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 11 September 2014, 19:31:30 »
Car going at 20-25. Mash foot to floor. Steady build up of revs. Doing bit faster... 30-40 for example. Car kicks down and flies.
Is this right? Or should it kick down at those slower speeds too?
RIP Paul Lovejoy
Re: Stupid kick-down question.
« Reply #1 on: 11 September 2014, 20:02:41 »
Should be instant throw back into seat at any speed , well tis in 3.0  ??? Although depends how long you been driving around like Granny Bear  ::) ;D
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #2 on: 11 September 2014, 20:13:12 »
Kicks down here at any speed? tried it again just for you  ;D :y
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #3 on: 11 September 2014, 20:25:44 »
Should go like a stabbed rat at those heady speeds LOL
Is it same when in 'S'...?
D.I.L.L.I.G.A.F...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 11 September 2014, 20:36:31 »
I feel like the kickdown works best on mine without sports mode, But as has been said it should throw you back into the seat either way  ;D
Webby the Bear
  • Northampton
« Reply #5 on: 11 September 2014, 21:43:48 »
Yeah same in sports mode.
Wonder why. Any ideas? ill check the throttle cable isn't slack but pretty sure I did that before
RIP Paul Lovejoy
« Reply #6 on: 12 September 2014, 11:31:48 »
Usual cause is to much slack in the throttle cable on the cable throttle setups.
« Reply #7 on: 12 September 2014, 11:33:33 »
Or the wrong engine on dbw cars ::)
« Reply #8 on: 12 September 2014, 11:35:08 »
All DBW cars are the wrong engine  ;D ;D ;D :D :D :D :y
« Reply #9 on: 12 September 2014, 11:37:42 »
Oooh, a cynic ;D
« Reply #10 on: 12 September 2014, 13:06:28 »
Oooh, a cynic ;D
I have always considered the optimum to be a 3.2 block running 3.2 heads and manifolds with a 3.0 injection setup  :y
« Reply #11 on: 12 September 2014, 13:07:27 »
With a proper gearbox, I trust ::)
« Reply #12 on: 12 September 2014, 13:35:09 »
Oooh, a cynic ;D
And 3.0l pistons, to get the CR back up (and sod the tree huggers)
« Reply #13 on: 12 September 2014, 13:49:36 »
Might get a bit of piston slap on account of the 1.5mm clearance in the bores, mind. ::)
« Reply #14 on: 12 September 2014, 13:53:33 »
Oooh, a cynic ;D
Fit 2.5 heads with a bit of porting  :y
Pages: [1] 2 3 4 5   Go Up
