Author Topic: New noise  (Read 3627 times)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
New noise
« on: 12 September 2014, 08:09:36 »
She started a new noise last night from front suspension. It's a hollow sound as if the header tank was empty and loose and clonking against the body, if you can imagine.
Worse on slightly uneven road surface than over speed humps. No noise on good, new road surfaces.
Braking and steering still good.
She's done 126,000 on original drop links. Could it be them ?
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: New noise
« Reply #1 on: 12 September 2014, 08:12:39 »
Either drop links, ball joints or top suspension bearing....
D.I.L.L.I.G.A.F...
Re: New noise
« Reply #2 on: 12 September 2014, 11:08:20 »
Droplinks it is :y
Paddy Flannery
    • 2003 2.6 V6
Re: New noise
« Reply #3 on: 12 September 2014, 13:00:06 »
Cheers guys. Typical that this starts when the MOT expires next week  ;D
Re: New noise
« Reply #4 on: 12 September 2014, 13:36:23 »
Always the way ::)
rockabilly
  • Tetbury
    • omega2.2 auto
Re: New noise
« Reply #5 on: 12 September 2014, 14:30:04 »
Have had a similar noise sound on mine, It was like a loose golf ball rolling around it was not there all the time, in fact I took the mechanic up the road with me to prove the noise was there. not always but every so often there was this dull knock.
I had replaced every thing, even had top suspension strut bearing replaced thought it sounded if coming from there, guess what not even that worked.
Went back to garage, they put car on ramps, we went underneath again and shook, banged and pushed every thing found nothing new.
Mechanic then said your Steering tie rod ends feel a bit stiff, let spray some Wd40 on the two end joints, we had nothing to lose,
Now more noise knock completely gone? it could be worth a spray !!!!!,but what do i know,best of luck.
2.2 115000miles Y Plate
Rockabilly
Paddy Flannery
    • 2003 2.6 V6
Re: New noise
« Reply #6 on: 12 September 2014, 18:46:47 »
Rockabilly, that's a cheap fix  :y
My MOT man will chuck it up on the ramp prior to going into the MOT bay to see what's what.
I'll hopefully report back with the diagnosis and new ticket next week !!
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: New noise
« Reply #7 on: 12 September 2014, 22:24:04 »
Always the way ::)
took my carlton in for mot the other week, knew it was good so didnt bother to check anything. lol only to find a broken rear spring :-[. first car ive had fail in years. that will teach me.  :D
Paddy Flannery
    • 2003 2.6 V6
Re: New noise
« Reply #8 on: 18 September 2014, 16:35:53 »
She passed her MOT.
It was the drop links as diagnosed above.  :y
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
Re: New noise
« Reply #9 on: 18 September 2014, 18:11:06 »
Top marks for taxi al  :y
Page created in 0.075 seconds with 20 queries.
