Author Topic: Cam Covers  (Read 4102 times)
Cam Covers
« on: 14 September 2014, 01:57:21 »
At last cam covers done today.  Gaskets and o-rings were brittle, with 5 of the 6 plug wells full of oil - suprised car was running ok with no misfires!!
Drivers bank fitted with Payen gasket set from allgermanparts and gm o-rings, and passenger bank fitted with a gm gasket set and gm o-rings.  As stated before the Payen set feels as supple and pliable as the gm set, and the fit to the cam cover was same for both types.
Time will tell!! - will update Payen performance vs gm as mileage increases ;)
Plug wells cleaned out, coil packs cleaned up, and new plugs fitted - still got a smoke screen when started up, but cleared reasonably quickly.
« Last Edit: 14 September 2014, 02:00:11 by dbug »
Re: Cam Covers
« Reply #1 on: 14 September 2014, 08:40:39 »
Excellent  :y Ive done 1000 miles so far on non genuine cc gaskets , they were very supple unlike any bought before . Used a different method of fitment  ;) Parts were £16 for a full set .
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Cam Covers
« Reply #2 on: 14 September 2014, 09:02:53 »
Ohhhh you pair of rebels  ;D, never had issue with patten gaskets myself so fingers crossed they are both ok :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Cam Covers
« Reply #3 on: 14 September 2014, 09:08:48 »
O no hieratic, the black ghost will appear outside your house,you will be cast out. :D
Remember the first rule of pattern parts.
Don't tell middle earth :) :D
Hoof'land storeman.
chrisgixer
Re: Cam Covers
« Reply #4 on: 14 September 2014, 09:34:16 »
Dbug has said previously that he will test these on the drivers side on behalf of forum to see if they are any good.
Re: Cam Covers
« Reply #5 on: 14 September 2014, 10:44:45 »
Yup,keep us updated dbug :y
Worth checking plug wells on a monthly basis, and also around the outside edge and the back (by the half moons).
Thanks :y
Re: Cam Covers
« Reply #6 on: 14 September 2014, 23:23:51 »
No probs - cars done 250 miles today - no issues with oil loss (although never had to top up oil in past, even with the leaking gaskets!!) and plug wells still clean. :y
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Cam Covers
« Reply #7 on: 15 September 2014, 12:42:06 »
Watching this with interest :D
Vicar
  • staffs border
    • 2.0 CD
Re: Cam Covers
« Reply #8 on: 15 September 2014, 17:44:49 »
Haven't looked at mine on my 4potter but do they also need o rings and where are these o rings?
Re: Cam Covers
« Reply #9 on: 15 September 2014, 18:09:45 »
Yes - sit just under cam cover where the bolts go through
Vicar
  • staffs border
    • 2.0 CD
Re: Cam Covers
« Reply #10 on: 15 September 2014, 18:32:05 »
Ok, thanks for that. Had thought it would just be the gasket to swap. Shall check mine when I do the pollen filter.
kevinp58
  • kent
    • 2002 3.2 elite
Re: Cam Covers
« Reply #11 on: 15 September 2014, 22:49:15 »
Payen used to be a quality product thought they had gone the same way as Quinton Hazel.  :-\
