ECG
Started by omega3000, 14 September 2014, 12:20:19
Glad to hear it was nothing too serious Mr Emd.  :y
Quote from: Sir Tigger on 14 September 2014, 21:07:42
Thanks all  :)
Only thing now is im getting worried again  :(
The pain has shifted from under and around the ribcage to under the shoulder blade on my back on the same side  :'( Its a constant stab stab pain  ::) I dont like to be a pain keep going back to the doctors but this is worrying  :-[
Quote from: cem on 14 September 2014, 19:02:32
Emd, did they make an effort test ?
Not sure what that translates to Cem ? Had a full physical examination .
the alarming man
basically glad it was nowt serious and ECG would have showed anything untoward going on...but trust me if you were suffering a heart attack I doubt you would have been able to drive yourself anywhere...best repair for a torn muscle is rest and sleep :y
Quote from: Emd on 14 September 2014, 21:14:43
I presume Cem means what we'd call a "stress test" - i.e. stick you on a treadmill and get you going at max chat while wired up to machinery to make sure you're not about to expire..
The Sheriff
Quote from: aaronjb on 14 September 2014, 21:58:54
I don't have chest pains at the Mo, but I'm fickin sure I would if they did that  ;D
yep.. any heart problem will come to surface within meters ..  also there is a recording device for heart that records you 24 hours at least..
ok.. forget all those ,   any problems related to digestion,  or bulginess around abdomen area ?
Quote from: cem on 14 September 2014, 20:27:48
Quote from: Stuart30 on 14 September 2014, 20:13:33
Cem everything is an effort on the NHS... ;D
I agree ..  :)  but in our ages, arteries start to contract  and be blocked easily which effects all system..  most of the time misdiagnosing is more easy than the correct one when one problem clouds another deeper one.. I do believe a diagnosis must double guarantee its correctness by multiple tests..
I have to agree with Cem on this, swmbo has had a terrible time with misdiagnosis over that last couple of years, blocked artery in the foot eventually diagnosed, ultimately leading to recent heart op............. :-X :-X :(
chrisgixer
Many moons ago ::) I twisted a collar bone in the joint (clavical ?) which didn't hurt at all at the time, but swelled up and was very painful for years after. As part of this I now have over stressed chest muscle holding the shoulder in place. Something I'm not aware of until I relax and then the muscle relaxes. But when it does so its very sudden and feels like a palpitation. A big one. Coupled with an amount of pain that radiates down the left arm and covers the chest, well, you can guess what that might feel like.
Thing is panic sets in and heart rate goes through the roof. ;D or used to. Now I know what it is there no panic and I can control it.
Thing is, obviously, unless you've had a heart attack in the past and know what that's like, you do assume the worst. Something my GP couldn't possibly understand. Arrogant tw@!
Anyway. Not to be taken lightly, but there are looooads of symptoms in the upper left torso that can be very worrying.
all of us are under a high risk with this nutrition habits, high daily stress and low exercise habits..
its a no brainer that if surgeons had time to cut any of us randomly  ;D  to investigate ,  they will face high fat oiled nearly non-working inner organs , contracted blocked arteries with weak joints + muscle groups here and there.. :(
better safe than sorry..
Jusme
I dont lift heavy things and only took a headlight out the carYou don't have to be doing much EMD. A few weeks ago I was hoovering when I got terrible chest pains and a pain in my jaw. (another indication of heart attack.) Stupidly I finished hoovering. Sat myself down, my wife's carers phoned for an ambulance. Wouldn't go with them until my sister arrived to look after the missus. 2 hours later I was on the heart ward complete with 2 stents fitted... :y did they make an effort test ? As I also have emphysema I would not have been able to do that.  :( So what then Cem? The most painful bit was pulling off those sticky monitor bits, bejesus that smarted.So pleased I'm not hairy... :o ALWAYS err on the side of caution EMD, 'better to be safe than sorry'... Take care  :y
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Thanks for the kind words  :y Still no relief as of yet but i did get a good few hours sleep last night . Only slight relief is if i lean away from the painful side  :( Deep heat rub helps slightly , painkillers "12 a day" dont seem to be working although they do knock me out at night so i can sleep  :( Doctor said it will take at least a week for any improvement and up to 3 weeks to fully heal  :-\
Jusme
Good painkilling remedy I find is, paracetemol and tramadol, not taken at the same time but about 30 minutes apart...
The Sheriff
Quote from: Jusme on 15 September 2014, 18:06:31
Getting hold of tramadol (or trauma doll, as my gaypad likes to call it) isn't easy.
chrisgixer
Quote from: STMO on 15 September 2014, 18:27:18
Oi, now no jacking the price up Esta.
Quote from: chrisgixer on 15 September 2014, 11:01:40
Nah, I'm with your quack. I always assume the best when it comes to my health.  I usually mend. Eventually.
