Author Topic: Complaicent about Rear Axle  (Read 1493 times)
Big_Roger
  • Southampton
« on: 22 June 2008, 20:39:20 »
Hi,
Checking rear axle oil level was one of the things on my list of things to do when I first got my Omega late last year.
However, as it didn't seem to have much of a leak from the input shaft seal, I wasn't too bothered, and there were so many other things !!!!
Finally got round to it today, surprise surprise, it needed 700ml to bring up to oil level/filler hole. Much more than I expected.
Don't leave yours too long before you check it out
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Andyb
  • Lincoln
Re: Complaicent about Rear Axle
« Reply #1 on: 22 June 2008, 20:42:04 »
have to check mine asap then me thinks  :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 22 June 2008, 21:17:36 »
need check mine ,what oil U use for top up
Big_Roger
  • Southampton
« Reply #3 on: 23 June 2008, 12:02:45 »
Hi,
Oil required is EP90 differential oil.
I used some Motul AP 90 which was on a special offer from Opie Oils when I bought the 10 Litres of Titan 4000 (Dexion 3 equiv) for auto gearbox oil change.
Although I don't think I have a limited slip differential, as car is ex plod I couldn't be sure. The Motul AP 90 is a differential oil but also has additives to make it suitable for limited slip differentials as well.
HTH
Roger
« Reply #4 on: 23 June 2008, 12:58:26 »
Something that can get easily neglected.
