Author Topic: rejuvenate.  (Read 5381 times)
Vicar
  • staffs border
    • 2.0 CD
rejuvenate.
« on: 16 September 2014, 20:56:25 »
Hi folks. Having enjoyed using my ole motor for passed few weeks I am thinking I should start to treat the car to new items which will consist of, plugs, oil filters etc. I remember rightly, these have a external fuel filter outside of the tank? Are they easy to find and then fit, considering renewing the fuel line with copper one that I have excess of also, just so there's no cr@p left over. Are these fuel lines all rubber through to the front?
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: rejuvenate.
« Reply #1 on: 16 September 2014, 22:19:20 »
Except for the rubber hoses near the engine, the fuel lines are nylon pipe just like most cars for the last forty(at least) years. Why would you want to use copper for this? And how do you intend to join them to the specific fittings?
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: rejuvenate.
« Reply #2 on: 16 September 2014, 22:41:52 »
Are you even permitted to use metal lines for fuel anymore?  :-\
chrisgixer
Re: rejuvenate.
« Reply #3 on: 16 September 2014, 22:46:51 »
Why on earth would copper fuel lines be needed?
Vicar
  • staffs border
    • 2.0 CD
Re: rejuvenate.
« Reply #4 on: 16 September 2014, 22:48:21 »
Not quite sure on the two questions above. Have fitted copper line before and it's same size as was the nylon, I swapped it for so attached it in the usual way. Fuel pipe clamp onto 7mm rubber hose to intake area. Are copper pipes not allowed on cars?
Had thought copper line renewing the old nylon would be way forward, obviously not. :-[
chrisgixer
Re: rejuvenate.
« Reply #5 on: 16 September 2014, 23:01:49 »
Forward from what though. Copper was once used on lpg installs, now replaced by nylon. There are no known faults with the fuel lines. Its less likely to fracture. Is flexible and so less likely to leak or rupture if caught by debris from underneath.
What advantages do you see with copper...?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: rejuvenate.
« Reply #6 on: 16 September 2014, 23:23:40 »
none at a guess, i would leave well alone tbh.  ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: rejuvenate.
« Reply #7 on: 16 September 2014, 23:26:41 »
I think the OP wanted to remove as much crud as possible from the fuel system.  Seeing as OP has loads of copper pipe floating about, it seemed like a good idea to replace the fuel lines whilst under the car.
Back to OP - The filter, if doing it's job, would have stopped the crud from entering the fuel lines, ergo, no problemo.  :y
Vicar
  • staffs border
    • 2.0 CD
Re: rejuvenate.
« Reply #8 on: 16 September 2014, 23:29:04 »
I didn't see any advantage apart from just clean line and happen to have copper one lying about. I may leave it alone but I'll check on state of pipe when I renew the fuel filter,, I assume that's still fore if the tank and easy to source? :-)
If the filter is passed it's best, then they'll be cruddy lines?
« Last Edit: 16 September 2014, 23:31:12 by Vicar »
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: rejuvenate.
« Reply #9 on: 16 September 2014, 23:59:20 »
Unless the filter mesh has been compromised, nothing should get through.  :y
Vicar
  • staffs border
    • 2.0 CD
Re: rejuvenate.
« Reply #10 on: 17 September 2014, 00:08:09 »
Right, fuel line gets left alone then.  :) is the filter freely available? I'll swap that then see what I need under the bonnet. Maybe new leads are due too.
Re: rejuvenate.
« Reply #11 on: 17 September 2014, 18:10:45 »
Unless you have a specific problem, I'd leave the fuel lines well alone, they give little problem to be honest...
...except the little clips near the fuel filter that can go brittle, and without the right tools, can break when doing filter.
Filters are available most places, I use GM ones from dealer on Tradeclub, due to cost. Worth buying a pair of the clips "just in case", despite their high cost (nearly £1 each IIRC). Saloon piss easy to do, Estate a bit more of a pig. On either, expect a face full of fuel, such a small filter seems to hold a million gallons ;D
Re: rejuvenate.
« Reply #12 on: 17 September 2014, 18:14:28 »
In my experience dealers tend to throw the clips in for nowt :y
Re: rejuvenate.
« Reply #13 on: 17 September 2014, 18:18:59 »
Depends if you pay Retail, Trade or Tradeclub prices ;)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: rejuvenate.
« Reply #14 on: 17 September 2014, 19:32:24 »
I'd also have some spare mini jubilee clips and 10mm fuel line to hand also to do a quick repair if your plastic fuel line at filter end breaks....... speaking from experience  ::)
RIP Paul Lovejoy
