Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Specific differences between X30XE and Y32SE?  (Read 32765 times)
Re: Specific differences between X30XE and Y32SE?
« Reply #45 on: 29 September 2014, 11:28:19 »
So to answer, the Saab heads should get your compression ratio back up (I say should as we don't have visibility here of any US specific mods that might have been done).
On the 1.8/2.0/2.2/2.5/2.6/3.0/3.2 Euro Ecotec engines, all the inlet and exhaust valves are the same size so the exhaust valves will fit no problems (plus they just don't wear on these engines so second hand is ok).
The porting procedure requires the inlet tracks opening out to match the inlet setup as the 2.5/2.6 track is slightly smaller than the 3.0/3.2.
And to correct an earlier post, the G cams were fitted to the 3.0 inlets (not the exhausts) and the 3.2 did not have the same cams.
Matchless
  • Nottingham
    • A white van
« Reply #46 on: 29 September 2014, 13:44:58 »
Just to add to the above,
All the cams are engraved with an identification letter near the drive end. There is also a number which I believe relates to the profile grinder it was made on so an A3 is an 'A' cam, G1 a 'G' cam etc. Can be difficult to see unless cleaned properly.
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
« Reply #47 on: 29 September 2014, 18:15:05 »
Thank you all! This kind of info is hard to come by over here. There's such a negativity towards the Catera that good cars with minor problems are getting crushed everyday. It's very unusual to see one on the road. In fact I passed one today while returning from a doctor appointment with my Father. It was coming at me and when we passed the driver waved at me. I gave him the thumbs up. I almost crapped my pants. It was a Catera Sport, same year, same color as mine. My Pops thought I was having a stroke. You have no idea how rare a sight it is. I appreciate your help stirring interest in our cars and maybe keeping a few more on the road. They're all about "MORE POWER" here so maybe this info will inspire the DIY mechanics out there to breathe a little life into their Cateras. Thanks again.
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
elvin315
« Reply #48 on: 29 September 2014, 18:52:30 »
Last thing, I promise. Which Fuel Pressure Regulator should we use, and how much increased HP might we expect to see? Our L81 was robbed of 20HP and our top speed lowered to 120MPH so we'd like to get at least some of the power back if not the top speed.
« Reply #49 on: 29 September 2014, 20:55:44 »
Here, the 2.5/2.6 uses a 3 Bar regulator, and the 3.0/3.2 uses a 3.5 Bar regulator :y
« Reply #50 on: 29 September 2014, 21:16:31 »
Not quite right.
The 2.5/3.0 had a 3bar and the 2.6/3.2 had a 3.7 bar.
Upping the fuel pressure will give no extra bhp, it might give slightly better fuel atomisation and if you were struggling to fuel it at WOT it could help there to (but they don't stock)
« Reply #51 on: 29 September 2014, 21:19:57 »
My bad :-[ was off memory... which is clearly off ::)
« Reply #52 on: 29 September 2014, 21:24:43 »
Lol, I only know as I used to advise raising the fuel pressure on the C25XE in the Cav and Calibra and the best source was an FPR from a 2.6 or 3.2  :y
elvin315
« Reply #53 on: 30 September 2014, 23:09:29 »
Anyone willing to take a guess at the HP from this "Bastard" engine? (OK, sue me. I had another question.)
« Reply #54 on: 30 September 2014, 23:20:12 »
220 bhp ish :-\
elvin315
« Reply #55 on: 01 October 2014, 00:12:54 »
The US spec LA3/Y32SE, as used in the CTS, is already rated at 220HP. I'm sure swapping the 3.2L heads for the 2.5L or 3.0L heads (with the G cams and sodium filled valves) would bump up the HP but by how much?
« Reply #56 on: 02 October 2014, 08:43:04 »
A well put together 3.2 with the increased CR and a little fettling on the inlet plus the better cams should see around 230-240bhp
elvin315
« Reply #57 on: 02 October 2014, 22:14:03 »
Sounds good. Thanks.
elvin315
« Reply #58 on: 10 October 2014, 05:43:19 »
"A little knowledge can be a dangerous thing."
I gleaned a little knowledge about camshafts following you guys, made the mistake of digging deeper, and found this:
The chart lists the X30XE's 2x"G" & 2x"A" cams but there's no mention of the 4x"G" option. Forgive my ignorance but does 4x"G" mean using "G" intake camshafts as both intake and exhaust? Try not to laugh at the stupid Yank but I'd rather ask a dumb question now than do something even dumber later.
« Reply #59 on: 10 October 2014, 08:07:09 »
Yes, exactly that.
G's in both inlet and exhaust
Pages: 1 2 3 [4] 5  All   Go Up
