Author Topic: Rear window mechanisam went bang  (Read 2205 times)
Stu C
  • Gatwick
« on: 20 September 2014, 09:17:21 »
Doing up rear window yesterday and it got half way up before going bang! and getting stuck. At first i thought the glue had failed on the bonding plate to the glass but after removing the rear door card I found a mess of broken platic bracket and steel cable :(  Anyone else had this problem and fixed it
  • Online Online
Re: Rear window mechanisam went bang
« Reply #1 on: 20 September 2014, 20:58:37 »
Sorry Stu, but it appears that you're alone in this problem. I can only suggest a complete 'new' mechanism ..... assuming it's the same as the front, the mechanism will be pop riveted in place ....... not too difficult.  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 20 September 2014, 22:00:15 »
No but similar, its fairly straightforward to replace, I got a spare for a about £12 on the net. There is a How to in the maintenance section. :y
« Reply #3 on: 20 September 2014, 23:56:54 »
Billy Bridges at Pease Pottage have a face lift estate and pfl saloon, window mechs the same across the range...
You will need a Dremel or cordless drill though as the mechs are riveted in place :y
Stu C
  • Gatwick
« Reply #4 on: 21 September 2014, 06:30:35 »
Thanks peeps :y
