Author Topic: Found a bolt in the sump .....PLEASE HELP!  (Read 6323 times)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: Found a bolt in the sump .....PLEASE HELP!
« Reply #15 on: 22 September 2014, 09:42:41 »
If it was me I would be getting sump off and getting it back on. Easier replacing a bolt rather than a whole engine
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
« Reply #16 on: 22 September 2014, 10:37:28 »
You cant get to it by just pulling the sump pan off or I would.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #17 on: 22 September 2014, 11:07:50 »
You might be able to get at it with just sump worst case you need to drop upper sump divider thing off as well
carswaps
  • West Yorkshire
« Reply #18 on: 22 September 2014, 11:16:56 »
There looks to be the main oil pan and the another which is above the cross member and also bolts to the gearbox (its an auto) can this second section be removed in with the engine in the car?
« Reply #19 on: 22 September 2014, 11:44:48 »
Yes, you can but you will need to lift the engine a couple or three inches to get enough clearance :y
carswaps
  • West Yorkshire
« Reply #20 on: 22 September 2014, 11:48:11 »
Thanks for that  :y
