Author Topic: Is it the scuttle drain?  (Read 7058 times)
Re: Is it the scuttle drain?
« Reply #15 on: 25 September 2014, 18:31:03 »
Thought being a drain rather than a plug this would be obvious. The maintenance guide for it is clear enough :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #16 on: 25 September 2014, 19:12:10 »
Ah, "play well". you over-estimate my intelligence! Yes, I got the term "drain", but in those murky depths I can see naff-all and could not for the life of me see how it could be a drain when all I could feel with a long, thin stick was a blind grommet and no drain hole.
Thanks for the clarification, "robson", I will get some kind of light down there and keep poking.......
Ron.
« Reply #17 on: 25 September 2014, 19:37:22 »
 ;D the drain rubber is directly underneath the wiring loom you can just get a finger to. It exits through a separate hole which is kind of tucked between the bulkhead and chassis rail a little ways south of the PAS reservoir :y
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
« Reply #18 on: 25 September 2014, 19:53:28 »
if you find it daunting to remove the carpets, why not beg, steal, borrow or hire a good quality wet vacuum and suck the worst of the water out !
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #19 on: 25 September 2014, 20:24:14 »
You have to have very small hands to get a finger down to the grommet. Sounds a bit rude :y
tport
  • east mids
« Reply #20 on: 25 September 2014, 20:33:17 »
Bigron
  • Witham, Essex
« Reply #21 on: 25 September 2014, 20:33:49 »
Not only great advice but entertainment on here as well! Thanks, "robson", but my fingers are big and fat (like the rest of me), as those who have seen much of my typing will testify - quite good for other things, though......
Ron.
tport
  • east mids
« Reply #22 on: 25 September 2014, 20:37:42 »
« Reply #23 on: 25 September 2014, 21:56:45 »
Agreed. I used a pair of long-nosed pliers to pull it out. :y
Bigron
  • Witham, Essex
« Reply #24 on: 25 September 2014, 21:59:38 »
Is that rude as well, Doctor Opti?
Ron.
« Reply #25 on: 25 September 2014, 22:20:16 »
Be careful if your pokingk it  ;D as you can damage the loom  :(
« Reply #26 on: 25 September 2014, 23:46:34 »
Carpets out is the only way to dry it out properly...
Rear carpet has 3/4" undelay stuck to it and the front carpets sit on what looks like a type of rubber, but is infact a sponge with a hard crust to it. Both these will trap moisture, leading to rusting and damp related problems.
Besides, removing/refitting the carpets is about 30mins work at most :y
