Author Topic: Paper Clip Test Not work!!!  (Read 1065 times)
wesagog
« on: 24 September 2014, 17:23:35 »
Hi,
I have omega B 2.0l model 1996 (manual Transmission)...
I have a problem of unstable RPM when I stop my car, each time when I stop and put the gear stick on Neutral it reach 2000 RPM and stay for (10-20)sec and then start to move to the normal level gradually.
Because of the above, I tried to do the Paper Clip Test ( which I did it many times before about a year a go) bu this test not works and the EML Not Flashes.
I need your help please about the both problems above, the unstable RPM and why the Paper Clip Test not works.
Thanks.
Ali
Re: Paper Clip Test Not work!!!
« Reply #1 on: 24 September 2014, 19:15:34 »
Clean the ICV, and check the intake for any air leaks.
Does the eml come on with the ignition? If so, no flashes means no codes :)
