wishbones
Started by cnj, 25 September 2014, 17:38:37
I recently bought and fitted ATP wishbones and so far so good!  :y
Quote from: Sir Tigger on 26 September 2014, 12:40:58
They have consistently lasted 20 times longer than the last pair of Delphi ones I bought :y
Diamond Black Geezer
Quote from: Doesn't play well with others... on 26 September 2014, 12:32:05
The combined single listing has been as low as £80, and prices are usually a touch lower on the ebay.de site :y
As ever, it pays to have a rummage :y I wouldn't buy budget wishbones from anywhere else though...
Not even for a 90p saving ;D
Haha, no, very true. That 90p saving I quoted does come from their own listings, by the way, that wasn't from Halfrauds or similar.
I'll hunt around for a cheaper combined amount. At my local Unipart I'm sure wishbones had gone up to about £60 a side, or similar (and they last 1-2 years  :( )
chrisgixer
Uni part ones are as shocking as Delphi if the owner of the car I had on my drive has remembered the name if his supplier correctly.
Yeah... I'm not having them on the V6... the fact that you pay what is a fair whack for a geometry set up (and it's worth it and not knocking the guys that do it, its a fine art when done well) and in a year you've got rubbery, spongy suspension that's already wearing and not 'tight' like it was. I can confirm from 1 week being in a PFL on Unipart...everything, to a FL which was at the time probably still on original VX items all round, the tightness and solidity was like going from a Citroen to a Volvo.
Quote from: cnj on 25 September 2014, 20:45:13
no, my time is yet to come. first problem is to get it running again, had to tow it home from school yesterday after it died (obviously it didn't like school ) after meeting the granddaughter. had stopped and started several times without incident until then. new fuel pump relay coming tomorrow which will hopefully solve the problem.
On a 2.2 I would be looking more towards cam sensor, I don't recall fuel pump relays causing any issues on Omegas.  :y
cnj
thank you sir for your words of wisdom, relay changed to no avail. current symptoms are cranks but not firing but every now and again it almost tries to start, but then reverts to cranking only until you have flatten the battery. I seem to remember having a problem with a fuel pump many years ago on a 2.0lr, can you advise whether it should whir/tick when the ignition is on ?
