Author Topic: Boot opening switch question  (Read 2401 times)
powerslinky
« on: 28 September 2014, 10:20:55 »
Hi all
         '53 plate 3.2 elite . . .  boot will not open with dash switch . ~have allowed the usual 3-4 seconds & still no workie :'(
tried with ingition on & off   & with key removed . .  still not working.
Boot opens fine with key fob  . . but not from switch .   Have checked fuse 7  & all ok
Any ideas where to look next . . .  possibly another fuse ?
TIA    Al :y
EDIT:    as this is my project car  . .  I am not sure if it has ever worked from the dash  :-\
« Last Edit: 28 September 2014, 10:22:29 by Essex Big Al »
Re: Boot opening switch question
« Reply #1 on: 28 September 2014, 10:37:56 »
Check the switch works first
powerslinky
« Reply #2 on: 28 September 2014, 10:43:26 »
Ah  . .  good point Jamie :-[ :-[  will swap with the MV6 one  :y
powerslinky
« Reply #3 on: 28 September 2014, 10:49:39 »
Yep  . . . switch is a good 'un ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 28 September 2014, 12:19:07 »
Is it Ex Plod, if so theres additional Relay modification in the wiring .
powerslinky
« Reply #5 on: 28 September 2014, 14:28:18 »
It's auto  . .  so presume not ex plod .    History shows owners as :1 Vauxhall demonstrator
        2 Previous owners father
        3 Previous owner
        4 Me
zirk
  • Epping Forest
« Reply #6 on: 28 September 2014, 14:53:27 »
        3 Previous owner
        4 Me
Ok Al, forget that then. :)
By the way there were some Auto Plods kicking around. ;) although the Autobox and LSD kicking in was a bit of a handfull  :-[
« Last Edit: 28 September 2014, 14:56:32 by zirk »
« Reply #7 on: 28 September 2014, 18:58:38 »
Reckon you'll have to start metering out wires from switch to Alarm ECU.  Its likely the problem isn't beyond the alarm ECU.
