Author Topic: Spanner size  (Read 5334 times)
Re: Spanner size
« Reply #15 on: 01 October 2014, 22:48:32 »
Damn. I'm thinking of bleed nipples. Bollards.
Trust you to be thinking nipples!!!!! Guess I was too  ::)  ::)
chrisgixer
Re: Spanner size
« Reply #16 on: 01 October 2014, 22:50:47 »
Nipples that bleed? :-\
Re: Spanner size
« Reply #17 on: 01 October 2014, 22:53:42 »
No ..... just nipples  ::)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Spanner size
« Reply #18 on: 01 October 2014, 23:52:26 »
Good set of tweezers and some strong fingers  :)
Re: Spanner size
« Reply #19 on: 02 October 2014, 01:23:04 »
15" adjustable wrench :y
Fark me, what are you changing the brakes on? 15" fittings! ;) ;D
Tis what I use for such situations... well defined jaws and a bit of leverage :y
Helfrods do/did a nice little set of spanners for such fittings, which will take a tap or two from sammy, either to install them or to turn them :y
Re: Spanner size
« Reply #20 on: 02 October 2014, 09:06:50 »
Ahh… 15" handle, not 15" jaws  :-[
That would definitely make my nipples bleed..
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Spanner size
« Reply #21 on: 02 October 2014, 09:12:50 »
That's what I thought Al meant too  ;D
RIP Paul Lovejoy
Re: Spanner size
« Reply #22 on: 02 October 2014, 18:50:44 »
I though they were 9mm  :-\
He told me they where 9mm....
.....as that size is missing from one of the Halfords sets Blah blah, and all that.
Yer nips, Gixer, 9mm is for yet nips.
:P
Re: Spanner size
« Reply #23 on: 02 October 2014, 18:53:09 »
Aye, that current generation of all sub 200pc Hellfrauds sets are missing 9 and 18mm, both used on Omegas. The 170 and 200pc are ratchet spanners, which I'm guessing do not like hammers.  Did I mention I miss my old 150pc sets?  :'(
chrisgixer
Re: Spanner size
« Reply #24 on: 02 October 2014, 22:25:18 »
:P
Needs something bigger than 9mil for my nips big boy ;D
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
Re: Spanner size
« Reply #25 on: 03 October 2014, 05:47:30 »
if not metric or a/f, try whitworth or bsf, failing that a gas torch !!
