Author Topic: Steering wheel judder/shake when brakes are applied.  (Read 11981 times)
« on: 04 October 2014, 15:20:09 »
Probably more steering wheel shake/judder under light braking than hard braking.
Front pads and discs changed 4 years and 30,000 miles ago......unable to tell if pattern or genuine VX parts were used.
Any idea, chaps? :y
« Last Edit: 04 October 2014, 15:21:41 by Doctor Opti »
Re: Steering wheel judder/shake when brakes are applied.
« Reply #1 on: 04 October 2014, 15:25:38 »
Invoice for £176.47 in April 2010.....which looks like one hour of labour  was required at £40 P/H plus VAT
Of course, the wobble/judder may have SFA to do with the discs and pads. :)
« Last Edit: 04 October 2014, 15:28:54 by Doctor Opti »
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #2 on: 04 October 2014, 15:31:16 »
Maybe drop links away ??
« Reply #3 on: 04 October 2014, 15:33:07 »
I hear much about these drop links .
What are they and where are they located?
Expensive?
Easy fix?
« Reply #4 on: 04 October 2014, 15:47:45 »
Won`t cause OP`s problems. Sounds like warped discs
« Reply #5 on: 04 October 2014, 16:21:16 »
I can also feel a judder/groan/grind through the brake pedal that is not the ABS kicking in.
How long do front discs and pads generally last?
« Last Edit: 04 October 2014, 16:24:35 by Doctor Opti »
« Reply #6 on: 04 October 2014, 16:27:08 »
Pads 5-25k depending on use...
Discs 10-50k depending on pad abuse :y
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
« Reply #7 on: 04 October 2014, 16:31:23 »
methinks our good doctor is in need of some new discs and pads and also some sensors by the sound of his description ! beware of some pattern discs as you may end up with warped discs and more judder.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #8 on: 04 October 2014, 16:44:25 »
Doctor Opti, I wonder if you are in the habit of holding the car on the foot-brake for short pauses after normal road braking? You describe the classic symptoms of warped discs due to such action. With braking, obviously the discs become hot and cool when the brakes are released, but if you hold the car on the foot-brake the disc area between the brake pads does not get a chance to cool, whereas the rest of the disc does - hence differential cooling takes place and the disc warps.
Ron.
chrisgixer
« Reply #9 on: 04 October 2014, 16:50:17 »
Look under the car at the inboard face of the frint brake discs. If there is a rusty band on the outer edge then replace the discs.
If not, front wishbone bushes are flapping about, although this usually gives a flapining or tank slapper( in bike parlance ) feel to the steering.
....as said, drop links are NOT responsible.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #10 on: 04 October 2014, 16:58:15 »
I have a works van when I brake the wheels shake. Had strut mounts, wish bones, brake pads n discs turned out it was drop links. Would I not be wise to check before he spends money on discs n pads. Only a suggestion n all
chrisgixer
« Reply #11 on: 04 October 2014, 17:05:03 »
Omega drop links have ball joints on each end. The slightest amount of play and they knock. Any knock is evident way before any effect on handling and body roll is evident.
It would indeed be wise though. But given the geometric set up and suspension design on omegas, it's not possible for the wheels to flap or the brakes to vibrate with drop link play. ...roll bar bush play might. But NOT the drop links themselves. Luckily, roll bar bushes on omega are a very rare failure.
« Reply #12 on: 04 October 2014, 17:06:09 »
Expensive?
Easy fix?
Take a front wheel off & you can't help but see one
click here
« Reply #13 on: 04 October 2014, 17:15:19 »
Fronts discs came up as an 'advisory' at the MOT in June.
001 Front brake discs worn,pitted or scored. But not seriously weakened.
« Reply #14 on: 04 October 2014, 17:16:43 »
Expensive?
Easy fix?
click here
Thanks, Andy.
They look relatively easy to replace if required.
No knocking noises at present. :y
Pages: [1] 2 3 4  All   Go Up
