Author Topic: V6 thermostat tube.....are they all the same size?  (Read 1711 times)
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
« on: 06 October 2014, 20:05:12 »
Does anyone know if the V6 thermostat tubes are all the same size across the V6 range?
I know the 2.5 and 3.0 have a different part number to the 2.6 and 3.2 but are they the same?
kcl
  • Finland
    • Volvo V60 D4 -14
Re: V6 thermostat tube.....are they all the same size?
« Reply #1 on: 09 October 2014, 10:49:58 »
You mean the coolant transfer pipe between stat housing and upper radiator hose? They should be all the same, wonder where you found different part numbers? O-ring between transfer pipe and stat housing were originally round, later square profile but they are also interchangeable so can not see any reason for the pipe to be different?
« Reply #2 on: 09 October 2014, 11:07:25 »
From my experience, they are all the same
andyc
  • Norfolk
« Reply #3 on: 09 October 2014, 17:15:43 »
Same on all V6's FWD & RWD apart from the Vectra C Z32SE
All V6's 90411629
Vectra C Z32SE 24447768
Andy
Thetford. Norfolk
