Air compressor
Started by omega3000, 07 October 2014, 21:05:44
Ok , its going to be mainly for spraying panels so i'll get away with 50 litre yes  :) Think ill buy new and save a whole lot of hassle . Ive got electric grinders
/sanders ect so can do without them being air  :)
Something like this one , got 2 year warranty  :y
50ltr
I don't think that's man enough, but I'll let those that are actually any good at spraying comment. But definitely hold off the Buy button until they do, as I think you'll be disappointed with that one.
Quote from: TheBoy on 08 October 2014, 12:10:09
Will do , there are a few that include the spray gun kits / blowers ect so just presuming they are good enough but will see what folk say  :-\
Like this one with all the kit Linky
henryd
Quote from: Emd on 08 October 2014, 12:13:50
Just because it comes with all that stuff doesn't mean its man enough to drive any of it other than the tyre inflator :D
other rides
Quote from: henryd on 08 October 2014, 12:21:37
That did cross my mind  ;D Probably spray a few model cars  :D
Start by looking for something with circa 14cfm if you can, this will be a 3Hp unit but will also be more expensive.
A rough priority order for me would be:
High CFM rating (14cfm ideally)
High HP rating (e.g. 3 which is most you can run of a 13A supply and will go with the CFM requirement)
Tank size - 50 minimum (if the CFM rating is high then the tank does not need to be so big)
Belt drive - generally more efficient so gives higher pressurised air displacement.
A key thing is, are you going to be spraying panels or a whole car. If a whole car then you need a quality spray gun, 100 litre tank and at the biggest compressor you can get. If just panels then a 50 litre tank will give enough stored air to complete the job with a reasonable HVLP gun (which generally operate at circa 50psi) and a smaller rated compressor will do.
Quote from: Marks DTM Calib on 08 October 2014, 12:31:14
Ah , thanks for that mark  :y Just for spraying panels , cars and fence panels ect ..
This one has 14cfm Linky  :)
That one looks identical to mine - different make but I bet they're all made in the same factory in China..
I haven't tried spraying so I can't comment on that, but it fills the tank fairly quickly and drives the windy gun, ratchet, grinder etc alright for almost every job I've done (besides taking the 32mm wishbone pivot bolts out of the back of a Jag diff which have a cone-shaped seat and took two of us and a 1m jack handle on the breaker bar to get undone ;D)
Quote from: aaronjb on 08 October 2014, 12:53:00
Thats good to know aaron , so bonus if it runs air tools  :)
They will all run air tools......the variable will be for how long  :y
Quote from: Marks DTM Calib on 08 October 2014, 13:09:22
Yeah - it'd be no good in a workshop, for sure ;D But it does alright for the air saw, die grinder etc at home.. although the blades that came with my air saw are a bit ... cheap ... and tend to heat the metal up more than they cut it ;D
Belt drive would be better, Emd, if you can afford a step up to one rather than a direct drive twin cylinder for the benefits that Mark listed above :y
Really must plumb mine back in - I miss it every time I have to take the wheels off something (yeah, I'm that lazy ;D and have a set of torque-limiting sockets for putting the bolts back in, too)
henryd
Quote from: Emd on 08 October 2014, 12:35:38
Thats better,if you can run to a bigger tank even better :y
other rides
kevinp58
Look at my link above it has a 90ltr tank and 14cfm £199 :y the 7.5 won't be enough, :y My old compressor was a 13.5 and only 50ltr tank and it was good enough to spray half of a car at any time so bonnet and side and then boot and other side also could do roof at the same time if I was lucky so for what you want it will be more than ample  :y :y :y you don't need an expensive one like some here say.  :-X
Missed that link - mine is the same make (WolfAir) but 50L 13.5cfm same as your old one - no problems with reliability so I wouldn't hesitate to get the bigger one you linked to for sure.
A spray painting gun will be no good for spraying fence panels IME. It will go everywhere but on the fence. Better to use a garden sprayer / killaspray type device.
