Author Topic: Exhaust back pressure, exhaust blockage and exhaust leak discussion  (Read 3815 times)
Re: Exhaust back pressure, exhaust blockage and exhaust leak discussion
« Reply #15 on: 10 October 2014, 13:22:52 »
Yep
If the cat to manifold joint was leaking you would get a whole host of issues including 02 readings which are off.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 10 October 2014, 15:11:33 »
Yep
I'm struggling to understand this so apologies for banging on
but the pressure coming out of the cat is high (exit - converge). the join is just after it, like in entwoods post.... a leak in a high pressure section...........
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #17 on: 10 October 2014, 16:27:42 »
In addition to my last comment.....
If the leak was around the manifold downpipe (before the O2 sensor) would that set a check engine light? And if not what am I looking for on the live data to tell me whether its not working properly (the cat that is)
RIP Paul Lovejoy
